Question about Samsung VP-D93 Mini DV Digital Camcorder
The tape fails to load on my Samsung VP-D93 with a ...D error.
An attempt to load a tape fails with a ....D error.
The manual states that this is a mechanical fault - and suggests that the recorder is switched off, the power removed and replaced - however this has not worked.
When the tape is inserted, there is a sound of a motor whirring quite fast before the tape is ejected instead of the 'tape cage' descending into the camcorder.
I suspect that the 'drive' to the spindles has failed - but I am reluctant to take the camcorder apart to check.
Can you advise?
Alan - of Warwick.
5 Suggested Answers
  • 1141 Answers
SOURCE: Instruction manual required. Can yoy help please?.
hey there
here you go you have all the manuals you need in diffrent langues and also some updates
http://www.samsung.com/download/Model_Select.aspx?type=Camcorder&typecode=7&subtype=Mini-DV&subtypecode=701&model=SCD5000&fileType=UM
Also try this
http://downloadcenter.samsung.com/content/UM/200312/20031208202142375_D93-UK.pdf
Hope this helps
Tom
Posted on Apr 10, 2008
Clog2020
  • 81 Answers
SOURCE: samsung vp-d361
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Posted on Apr 18, 2008
  • 848 Answers
SOURCE: samsung vp d20 camcorder
MiniDV cameras have two video heads on the rotating drum, which read and write the picture in broad horizontal bands. When one head is not working, normally because it is clogged by dust/dirt/tape residue, you see broad bands of noise across the image occupying exactly half the total image area.......
Posted on Aug 22, 2008
cpt100
  • 154 Answers
SOURCE: condensation operation of camcorder paused
Condensation problem is a common on newer camcorders. It is the sensor on the board that detects the condition of humidy. If you have not wet the camera or stored it in the humid area, the sensor or components around sensor is faulty. You can try to dry any humidity using hair dryer at medium setting in about 6 inches away for less than 5 minutes toward inside of tape loading area (make sure loading mech is at opened position). If this does not work, take it to recommended local camcorder repair facility for a diagnostics. Good Luck. CRJ
Posted on Mar 26, 2009
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Samsung camcorder vp-d381 eject L fault
YOU CANT CLEAR IT. THIS SOUNDS LIKE THE TAPE TRANSPORT IS BAD. SOMETHING BROKE INSIDE TRANSPORT AND NOW IT WONT ALLOW YOU TO LOAD TAPES
Feb 21, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Instruction Manual for VP-D93i Digital Camcorder and AV Lead...?
Instruction Manual & Software
=> http://www.samsung.com/he/support/index.asp
AV Cable. Recommend any electronic store.
Dec 26, 2008 | Samsung VP-D93 Mini DV Digital Camcorder
Samsung vp-d361
  1. Eject the tape.
  2. Set to OFF.
Manual
Apr 18, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
EZECTING TAPE LOADER
  1. Eject the tape.
  2. Set to OFF.
Manual
Mar 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Where can I download software for my Samsung VP-D103i, to my computer?
where can i down load software for my VP-D103 please, i need to transfer my tape on to PC
Dec 24, 2007 | Samsung VP-D103i Mini DV Digital Camcorder
Cannot play tape nor record on tape
  1. Eject the tape.
  2. Set to OFF.
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Samsung VP-D93 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
