Radar antenna not rotating
Intermittently the RL80 display reads antenna not rotating. After removing the radome cover, I find that the message is correct. There is power at the radome power connections (12.3 volts). Often, if I remove the wires and reconnect, it works again for a while. The connections are clean & when I insert the wires, I tug a little to make sure they are secure.
A dealer checked the radome and found no problem with the terminal block or its connections to the printed circuit board.
I need to check voltage with the power wires connected to the terminal block (12.3 v was at the cable ends that connect to the radome but not connected).
Any ideas or other things to be checked. All other functions of the system (DMS 250 sounder, chartplotter, autopilot) work fine.
    Top Expert:
  • Office Equip... Master
  • 48,404 Answers
The 12 volt motor has a problem---possible needs brush replacement
Posted on Mar 20, 2017
  • 196 Answers
SOURCE: How to clear error code 0000003d
Is it a USB scanner? Look in System information\device manager to see if your scanner is at all recognized by the computer. If not, install the drivers that came with the scanner. If the drivers are already installed, use it with another USB cable to see if your own is the culprit. If the problem persists, replace the USB card.
Posted on Jan 30, 2006
SOURCE: samsung fridge freezer rs21dcns not cooling
press for diagnose the power freece and power cool, you will get an information about the self diagnosis. you can call samsung and will get a clue what is going on. maybe the heating is not working well.
Posted on Oct 01, 2007
  • 552 Answers
SOURCE: Sears UltraSoft 800 Water Softener LCD Display wonky
You need to ask at radio shack or similar electronics store for some kind of gell that will connect the rubber strip to the display. These displays show the information that runs through the rubber strip(fiber optics, I believe?).
It is critical to get a near perfect connection between the two.
Also for cleaning, I would ask a tv repair man what kind of spray solution he uses to clean circuit boards.
Also, whenever you are dealing with electronics, there is a possiblility of causing static which can wipe out a programmed chip on one of the circuit boards. That is why some components that are ordered come in a static free plastic.
Posted on Feb 07, 2008
  • 1224 Answers
SOURCE: Artec e +48u scanner
quite possible the scanner motor finnaly gave out but lets look at other things first
try connecting to another usb port on comp before that completly take out all of the scanners drivers and programs this could be a simple file corrupt
i know you tried this but sometimes putting a new driver over old driver doesnt usually change the old drivers properties this is when you completly take out all drivers and software and start from scratch for this scanner
Posted on May 15, 2008
  • 93 Answers
SOURCE: F7-E0 Fault code. All connections and components checked.
Change your temperature sensor first and check if cleared the code. If not change your control board.
Posted on Jul 24, 2008
Radar 1731 shuts down when tx is hit
There are a couple of things that could cause the radar to power off when going into the transmit mode.
The first thing to eliminate is input power. When in the standby mode the radar draws less current than in the tx mode so if you have low voltage for whatever reason, that could cause a shut down. Check all connections and measure the voltage to the unit while it is on.
A problem with the antenna motor or gear box could also be the problem. The antenna doesn't rotate unit the unit is switched to the tx mode. You would need to remove the dome cover (with unit off) and verify that the array will turn freely by hand. Typically, a bad motor will not cause a shut down but a physical obstruction could.
Focus on the power issue because that's the most common problem. Be aware that you need to measure the voltage as close to the radar display as possible and watch the voltage as you switch the radar from standby to transmit for a quick dip in voltage.
Jun 25, 2014 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Brg sig missing
That usually means the antenna is not rotating. Verify that first then check for physical obstructions. More than likely it's a defective motor assembly.
Jun 24, 2013 | Furuno 1832 Radar 36nm
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
Antenna not rotating
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
May 11, 2009 | Boating
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
The belt on the radome drive sprocket jumps off of
The belt pully on the motor has a set screw that tends to get loose causing the pully to change position on the shaft. Position the pully on the shaft (move up or down) for better alignment with the pully on the rotating array pully and tighten the set screw..
Feb 23, 2009 | Furuno 2.2kw 18" Radome
61 people viewed this question
