Question about Microsoft Computers & Internet
Usb port not recognising devices and mouse pad not responding
My mouse pad is not working as it used. all the usb port do not recognise any device inserted
  • 96 Answers
Hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Posted on Nov 27, 2008
My mouse wont get recognized
Have you tried to use the mouse in another computer to determine that the mouse if fully working. There are many reasons why it could be non-recognised. Has it ever worked on your system? Is it new and just a faulty mouse. It may be you could just take it back to the shop for a replacement one. Do other devices work in the same USB port. Some times my computer just stops recognising my USB keyboard yet it has been working for months. I found that it seems to be the USB port where the problem is. So not I just switch my mouse and Keyboard usb connectors around and it starts to recognise both again. I can not figure out why it stops. As another device is recognised suggesting the port is not faulty.
Nov 01, 2013 | Computers & Internet
SAMSUNG YP-T10J
First disconnect PC from power cable for 10 minutes (unplug).Disconnect player from USB. reinstall player software. Then connect back player, it should work.
Apr 20, 2008 | Audio Players & Recorders
I have compaq 610 laptop window7 . frequently external usb mouse stopping to work as well as showing that one usb device attached with this computer, window is not recognising it. By clicking i knew that...
hey Windows 7 stated, first time here in days, nobody ever tells OS.
you are a winner for savvy award 1000
old relic COMPAQ LT.
your LT now has 2 mice, and if you run 2 mice what happens
they try to get in a fight.
we must shut off the mouse pad first.
I guess this mouse is a MS mouse, no mouse name stated.
I shut off the mouse pad in device manager.
look for the USB mouse not, is this unstated mouse wireless, if yes a new battery is now needed. and matching usb dongle.
now plug in the mouse. PC goes DING donng.,
and it loads a driver
be in the internet to W7 can find the driver.
if still dead, go to device manager,
see that mouse there under. mice and other pointing devices
mine shows, HID mouse here.
if missing , plug the mouse into all USB ports 1 by one and listen for the DINGDONGg (means new USB device discovered)
if still fails buy a new mouse, gee barrow one for a day.
if that mouse works , trash the dead one.
you can not have 2 mice at same time or you get into trouble.
the old mouse pad , we had to use disable in device manager to kill it.
on the new HP we have newer driver and it has this.
" tab, automatically disable pad mouse with usb mouse active"
but old ones dont have this
I too hate pads. when the thumb hits the pad, I want to kill that pad fast.
one ebay a 5 pack of mice is $14
a 5 year supply, all mine fail in 1year, the wires snap near mouse inside, easy;
Jun 18, 2017 | Compaq Computers & Internet
Broken Usb wireless optical mouse
Hi Joseph,
Are you working this mouse on windows XP? Have you tried another USB port and ensured that the USB ports are functioning within the device manager?
Ensure that you are testing using fresh batteries.
http://www.belkin.com/support/dl/P74749-A_F8E874_man.pdf
Nov 01, 2017 | Belkin F8E874 Mini Wireless Optical Mouse
My wired mouse is not recognised on my laptop
I assume this is a USB mouse and it should work.
Attach the mouse and check your device manager that can be accessed by doing the following:
Find the icon for My Computer (XP) or Computer (Vista, Win 7).
Right click on it and then choose the hardware tab.
When that tab opens, click on device manager.
Check the mouse item to see if your mouse is recognized. It may have an exclamation mark on it. If so, right click on it and delete it.
Check the USB devices at the end of the list to make sure there are no exclamation marks on any. If there are, delete them.
Restart the computer to see if the devices are found. This should work. The only problem you could have is if the mouse itself is bad or if your motherboard is having a problem.
Jan 04, 2010 | Microsoft Wireless Mobile Mouse 3000
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
Usb ports
u can upgrade the bios in your pc by downloading the bios from the manufacturers site ,i thinkthat shld get it to work with the usb device
Jul 16, 2008 | Computers & Internet
Limited response with Expert Mouse
The correct address is graviskensington_support@xtrasource.nl
or you can fill out the online form.
Many Thanks
Sep 15, 2007 | Kensington Expert Mouse Trackball
Computers & Internet Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
