Question about Sanyo DWM395 DVD Player
Parental Control I can't turn my Parental Control feature back on. There's a four-digit code you have to enter to turn it to on or off and right now it's stuck on 'off'. I can't remember the code, so I'm going to need to reset the system or something. Can I do that myself? Is there anything else I can do?
  • traysee_w Dec 03, 2008
    I can't turn my Parental Control feature back on. There's a four-digit code you have to enter to turn it to on or off and right now it's stuck on 'off'. I can't remember the code, so I'm going to need to reset the system or something. Can I do that myself? Is there anything else I can do? tw
If you go to the password box and enter 788444 in the ____ and press enter, you should get in.
Posted on Jun 30, 2007
Turning off parental controls on Toshiba tv lcd 42hl800A
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Jan 05, 2017 | Toshiba Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
I need 4 digit owner pin for crackle parental control it won'tl let me enter the number unless I know it and they never gave me a four digit parental control number so how do I obtain it?
Only the person that set up the 4 digit code that knows the code can do it. There is no way anyone else can figure out what the code is.
Nov 14, 2015 | Video Game Consoles & Games
White screen with enter a 4 digit control pin and press select??? picture on both sides of white re fine!
It appears to be your parental control feature, or lock function. Try the codes 3001 or 1234 to reset the lock feature.
Press: Menu>Features>Parental Control(Child Lock)>Select,
then enter the code.
Nov 02, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Hoew do you put a code on your dsi
You can only put a parental control code on your dsi. this is how, On the Nintendo DSi Menu, use the stylus to select the settings ("wrench") icon.
Select the right arrow twice to reach the third page, then select "Parental Controls."
Select "Yes," "Next," then "OK" to reach the PIN screen.
Select "Next," enter a four-digit PIN, then tap "OK." Enter the PIN again to confirm it, then tap "OK" again.
Tap the up/down arrows to scroll through the secret questions. When the desired question is displayed, select "OK" to continue.
Select "OK" again, use the on screen keyboard to enter an answer to the secret question, then select "OK." The answer must be six or more characters long.
Select "OK," then tap the left/right arrows to scroll to the game rating icon for the highest-rated video game content that's suitable for viewing on the system. Select "OK" to continue.
The system will take you through a number of questions, where you'll choose which features to restrict. Select "yes" to block the feature or "No" to allow it. Select "OK" to confirm your selection
hope this helps
Nov 30, 2010 | Nintendo DSi Blue Console
The parental lock is on and I don't know the four digit password
My husband was playing with our remote and accidently put parental lock on. We could play cd's but not dvd's. Here is what I did. Go to the set up menu. Arrow over to the parental control and press enter. Arrow down to where to put your password in. Enter 0000 this is the factory default code. It will ask you to enter it again. then return to the main menu. I turned mine off with the remote then turned it back on, put a dvd in and it worked. My husband was ready to go buy a new dvd player. Power to the women!!! Hope it helps you.
Sep 01, 2008 | GE1401P DVD Player
Parental control feature
if you can get to the operations menu page, after selecting on or off next to parental lock, press stop button four times then press enter this should clear the security code. press the number keys to create a new code press enter.
Dec 08, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sanyo DWM395 DVD Player Logo
236 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
