Question about Compaq Presario Notebook
My computer does't read my cd or dvd
Is a PresarioCQ50-139WM a week old.
I don't see the E drive in my COMPUTER.
Also if I try to send any file or picture from my old Dell desctop computer to the new nootboock is telling me tha the C drive doesn't have inoff space even the have: 139GB free
Please hel me
Thank,
Carlos H.
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Cd/w/ dvd/r 522c is not reading nor writing just blank screen !
is it your computer screen that is black
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 22, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cd rom drive does not read cd or dvd
Dear i have send a link for solution of your problem.
this link can helps you and more helping of your convenient.
pls read this and open this link and you can solve your problem.
Thanks.
  1. Problem: Cannot read information on a CD or DVD.
    a. Check all the cables, monitor, keyboard and mouse functionality.
    b. Remove the disk and try to clean it with a commercial cleaning fluid or a clean damp cloth.
    c. Try to clean the disk drive with a disk cleaning CD or DVD.
    d. Try MS-DOS to copy the files from the CD or DVD.
    i. Click on Start->Run->Cmd (to start MS-DOS)
    ii. Type the command xcopy D:\*.* C:\cdcopy\*.* /v /e (D:\ is the CD/DVD disk drive and C:\ the hard disk drive.)
    iii. Stop or Exit from all other applications that maybe taking up too much virtual memory or CPU.
    iv. Restart the computer and try again.
    v. Restart in safe mode.
    vi. Switch the disk drive controller to DMA mode following http://support.microsoft.com/kb/310751/
    vii. For DVDs, unplug any cables that may be connected to the video outputs of the computer.
    viii. Update the DVD driver with the latest version of software from the manufacturer’s website.
    ix. Check that the sound card is compatible with the computer and use a DVD decoder for the drive.
    x. For DVDs, reduce the color depth, resolution and refresh rate using the Control Panel->Display options
    xi. Exit Microsoft meeting if it is running on the computer.
Feb 16, 2010 | Office Equipment & Supplies
''A disk error has occured'' upon start up
You cannot. (Remove any media from the diskette-drive and from the CD drive, and try again to reboot.)
The message is indicating that the disk-drive containing Windows is *NOT* readable. So, nothing can be read from the disk-drive.
Take the computer, and the original "IBM System Recovery" set of CD-ROMs, to a computer-store, and get them to remove the "dead" disk-drive, and install a new one, and to re-install Windows from the IBM CDs.
Maybe, while Windows itself cannot be read from the "old" disk-drive, the computer-store *MAY* be able to recover your "data" files.
Nov 06, 2009 | Office Equipment & Supplies
The InterVideo WinDVD 5 program on my laptop not working!
Maybe your CD/DVD drive is a old drive :O( , for the new cd´s/DVD´s on the marked today actually many times you need a new drive for read them. Try first if you can install with the dll found on the link below.
You can find "wnaspi32.dll'' here : http://www.dll-files.com/dllindex/dll-files.shtml?wnaspi32
Ohter solutions:
1: get a external drive(not to old) and try install it with that
2: copy the cd to a usb storage on a computer thats have a new cd/dvd drive, use the usb storage to install it on your computer, use the dll file from the link.
Hope this can resolve the problem.
Aug 23, 2009 | Intervideo Computers & Internet
Dell 8400 , does not show having the CD or DVD players.
Either get a new Drive because it is spoilt or format the Com. Try the first option first.
Jun 08, 2009 | Dell Dimension 8400 PC Desktop
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Model DRW 6S160PX06C
You cannot edit files *directly* on the CD/DVD. CD-RW and DVD-RW means you can "erase and re-burn" a cd or dvd, and reuse them like they were new.
You CAN however, just copy the files from the CD onto the hard drive and work from there. If you did that, sometimes files that are copied from a CD to the computer get copied with their "Read Only" flag set.
To undo that, in windows explorer, select the offending files that are on your HARD DRIVE, right click and go to Properties.
Uncheck "Read Only"
Click OK.
Now your files should be editable.
Again I emphasize that you cannot edit files directly on the CD or DVD. You can copy them to your computer, edit and change them as you see fit, and then re-burn the cd or dvd.
Jan 25, 2008 | NexxTech (DRW6S160PX) Burner
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
LG DVD drive problem
try getting the latest nero from their site- it sounds like you have an old version, or if it's loading from a cd- it's not reading it correctly.
Oct 29, 2007 | LG GCC 4480B CD-RW/DVD-ROM Burner
Compaq Presario Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
