Question about HP Compaq nc6000 Notebook
Nc6000 hi i have this problem i cant see the scream is all black but if i conect the regular monitor i see all i take the video card of and i put it back and works but now not working please if you know anything let me know
    Sergeant:
  • 177 Answers
Please make sure that your lcd brightness is at maximum. Consult your manual to adjust the lcd brightness.
Please let me know about the video card you have mentioned. Is it of the desktop?
Posted on Nov 24, 2008
Cant Find It. I opened the Desktop but I dont know what to look for. I need to take out the graphics card so I can put in in another computer plz help.
Hi, this sounds like an easy problem, and I am happy to provide the assistance.
First, open your computer.
Second, find the jack where your screen plug into it. It should look like this, or something similar.
This one has a jack for regular monitor, as well as as a high def jack called DVI.
Other versions have different jacks, from rca video out jacks, to 2 or 3 regular monitors, to s-video, to even HDMI
But this is the basic look of all video cards. It will be held into the computer with a small retaining screw that goes into the top of the front plate. Make sure that the power is unplugged, and then undo the screw, and you will probably have to wiggle the card back and forth to get it to come out of the slot that it sticks into.
When you put it into the other machine, you will need to check the bios settings so that it looks for the new card, otherwise you might not get any video signal out of it.
Also, after the other computer boots all the way up, don't forget to install the drivers and softwar for it, or else all you will get if a safe mode driver for your video card, with absolutely NO performance features enabled.
I hope this has been helpful for you today, and have a nice day!
Jan 28, 2011 | Computers & Internet
When I turn on laptop the screen is black
usually if you turn your computer on and the screen is black it is one of 3 things ram-memory,video card or the cable conecting the video card to the monitor often time the cable running from the monitor to the video card in laptops short out after being used for long periods
Sep 23, 2010 | Computers & Internet
Radeon 9600 is showing black and white picture
check to make sure monitor is pluged in all the way and check with another monitor. if no good check catalyst control center sharpness setting (if conecting via s-video) if not you will probably have to resolder the connections on the board
Aug 14, 2009 | Diablotek RADEON 9600XT Video Card -, ...
My screen goes black after startup
Try a different monitor, I am sure this sounds overly simplistic to you but, I have seen in my customers have just that, a bad monitor.
If another monitor does the same thing, then you should try another video card. If the video in on the motherboard, there should be a AGP, PCI-e, or an empty PCI slot to put a video card in.
Aug 08, 2009 | HP Computers & Internet
When i turn my computer on i get a black screen, no picture. i have put a new power supply and video card in and still the same results. when i mash the power button it will not turn off.
try another monitor . and on the video card try putting it in another i and o port they should be eather white or sometimes brown. if you cant get it to work it sound like you need a new monitor.
thanks
hope this works for you
Aug 19, 2008 | Computers & Internet
Dancing red pixels
Your Video Card´s DVI output is probably damaged. You will have to replace your video card , or use only the VGA output.
Aug 18, 2008 | Computers & Internet
Blank, black screen computer turns on, but the screen remains black. can hear the cpu running but cant see anything
Has this been happening on a regular basis? When did this start? If you have a separate video card are you capable of disconnecting it from the motherboard and attaching the monitor to the built in video?
Also as strange as this seems, I have seen some instances of a blank screen where motherboard ram not seated properly can lead to a no post situation.
Aug 17, 2008 | Toshiba Computers & Internet
Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
My monitor screen stays black when i turn my pc on help
have heard some beep,eihther long beep or short beep? if you heard a short beep replace your memory and when it is long beep replace your video card but if no beep,there is a problem in your motherboard
Nov 01, 2007 | Fujitsu Siemens Siemens Business Line 19P4...
The screen is white
This is the internal video card of the monitor.
It has either failed, or the cable that connects it to the LCD panel has come out of either the video card or the panel.
Hope that helps =)
Sep 19, 2006 | BenQ FP757V2 (Black, Silver) 17 in. Flat...
HP Compaq nc6000 Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
