Question about Dryers
Dryer does'nt get hot. do i need a fuse or a heating?
    President:
  • 331 Answers
James, are you serious? You ask a vague question with no make or model number. How in the world can I answer this? Answer? I can't. You must be specific... What's the make, what's the model, what's the serial, have you checked your breaker box, is it gas or electric? These kinds of things.
(You know that I do this for free, right?)
Tracy
Posted on Nov 23, 2008
  • Tracy Farrell
    Tracy Farrell Nov 23, 2008
    Sorry. I'm not having the best of days... Can you please provide some background info on your dryer? I'll do my best to assist you.
    Tracy
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Dryer is on and spins but does'nt heat up, what could the problem be?
probably the fuse in back of the machine, I had the same problem and that was the fix, easy to do.
Nov 15, 2011 | Dryers
My dryer runs but is not heating up. I am looking at the heating element and it does nt look bad. What else can it be?
Thermostats or thermal fuse more than likely. Use an ohm meter to check the continuity across t stats and thermal fuses. Get a cheap ohmeter at any hardware for around $12
Mar 24, 2011 | Amana NED7200TW Electric Dryer
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
THE DRYER IS NOT GETTING HOT
Verify that all breakers (or Fuses) are fine, Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Sometime, the dryer may heat, but it may not heat up as hot as it should. To repair, first check the vent hose. It must be clear for the dryer to work well. Make sure that the hose is not being crushed by the dryer. If the hose is very worn, or crushed, you'll need to replace it. The hose attaches to the back of the dryer and the outdoor vent with a spring clamp.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Jun 21, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
The dryer runs, but is not getting hot. Is there
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Feb 04, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
