Question about RCA F32650 32" TV
My RCA F32650 doesn't have a picture
My RCA F32650 Chirps when plugged in and when I press the power button it will chirp 2 or 3 times. I have no picture. I've determined that the chirp is coming out of P/N 1585161 AXE TCE. I'll try to find a schematic but if someone can give me a shortcut.. I could use the help.
  • Anonymous Feb 09, 2008
    have the same problem. The tv would go off and a few seconds later come
    back on. This happened several times and then we unplugged
    it. when we plugged it back in, now we have no picture and no
    sound except for the chirping. This doesnt change regardless of power
    on or off.
  • Anonymous Apr 06, 2008
    We had a similar problem with our four-year-old RCA 27-inch television (Model # F27442).  For several weeks, the picture would periodically go out leaving the screen black for several minutes each time.  We still had sound, but no picture.  This happened two or three times each hour.  Yesterday, the screen went black and the tv started making a high-pitched chirping sound.  We tried turning it off for a while, unplugging it, etc.  Nothing worked.  It's now headed for the trash.  We won't be buying another RCA tv.  However, our 15-year old GE still works great.  We'll be looking for another GE to replace the RCA!
    Genius:
  • 1,694 Answers
Replace IHVT aka flyback xformer--part#257805 or Asti 2078.
Posted on Oct 05, 2007
My horn doesn't chirp when I lock the doors.
My chevy doesn't chirp on the first press of the lock button, it just locks. If you press it again, then it chirps. To be honest, I like the fact that it doesn't chirp first - that just draws attention to the fact that you left your vehicle.
Nov 30, 2011 | 2004 GMC Envoy
How do you re program a replacement remote for the APS997A
To program remote; ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off.Test
May 27, 2011 | Car APS997A Two-Way Remote Start and...
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
5BCR07P PROGRAMMING INSTRUCTIONS
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
RCA 35" TV
Bad IHVT transformer part # 257805 or ASTI 2078......T.
Nov 22, 2007 | RCA F32650 32" TV
RCA F32650 32" TV Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
