Question about Sony Playstation 3 (PS3) Console
Audio plugin someone triped over cord and broke the plug inside the chair. How much would it be to replace the whole board.
    Problem Solver:
  • 12 Answers
Expensive if you take it somewhere but its easy and cheap to do it yourself you can order the parts if you call sony, sometimes you can find the parts on ebay. it be free if you bought the warrranty. let me know if you need any more info on it
Posted on Nov 24, 2008
Game mode not showing any picture
If you get a picture on regular TV then the tube is fine. If you get audio on game mode try changing the red or white plug to the yellow plug and see if your picture is there. If so you have a bad yellow cord. If not then the solder connection on the board inside TV is bad. If you also have no audio in game mode then the whole board is bad.
Apr 25, 2014 | Sylvania 6432TE 32" TV
Broke power plug plugin boaed
Take it to a repair shop. You will never get a replacement board for this.
Apr 13, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
I need a replacement plugin cord
if its just the plug from an wall outlet to the chair an old computer power cord will work fine. same plug
Oct 20, 2012 | Health & Beauty
BROKE OFF THE CABLE INPUT FROM BACK OF TV. AM I GOING TO NEED NEW BOARD WITH ALL PLUGINS ? MODEL 37LH20-VA OR UA THANKS DE
Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
Jul 12, 2011 | LG 37LH2000 37 in. HDTV-Ready LCD TV
MY RCA D52W20 TV NEEDED A REPLACMENT PLUG. I REMOVED THE WHOLE PLUG OUT OF THE BACK OF THE TV. I CAN'T FIND WHERE THE PLUG ATTACHES INSIDE OF THE TV?
the rca model itc222 chasis cord or plug runs to the front mains doubler board. this small narrow board is located in front of the large main green board. this board is a small narrow circit board behind that main board... on the right of that board there is the main fuse. next to this is the plug that the main cord plugs into
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The chair will not charge.
Greg,
You could have one or more of the following problems.
The batteries could be bad or too old to take a charge. The U-1 batteries for this chair can last between 1 and 2 years at most.
You have a bad charger cord which is making bad contact or is disconnected at the chair or the wall outlet. You can swap out this AC cord with a known good one.
The fuse at the charger is blown. The fuse is either at the back electronics console or in-line in a black boot fuse holder under the rear cover at the DC output of the charger harness. Check this fuse by holding it up to a light and checking to see if the filament is burned open. The fuse is a 7.5 amp ATO fuse usually.
The on-board charger is burnt out. This is harder to check since it is in the bottom of the electronics compartment for on-board chargers. Essentially, if the AC cord, fuse, and meter are good you should get up to 28 volts output at the batteries when they are connected to the charger output. You can pull the battery tray out or remove the base cover depending on model and put a digital voltmeter at the battery connector to test. Check the battery connections and plugs to make sure they are tight and connected.
If you have an off-board charger you can test the output and function of this charger the same way. With the off-board charger make sure it is plugged in and the switch is on before you make a voltage check at the battery connector (with the batteries plugged in).
Your most likely problem is the batteries. If the voltage is below around 18 volts, the on-board or off-board chargers will not turn on. If you can bring the voltage of the batteries up with a short term deep cycle charger clamped on the terminals you may be able to test the charger. You also need to have someone load test the batteries. If they are not holding a charge or load test weak or more than 2 years old replace them with new ones. A good technician can make all these checks in under 1 hour. The labor to replace any of these parts is also less than 1 hour. Hope this helps.
Dec 20, 2010 | Jet 3 Ultra Power Chair
Charger out 2nd time, under joy stick has plugin 3 pron. Can I use a off board charger. Batteries and charger changed june 09 Fuse not blown Power cord not shorted Breaker not triped.
Yes, you can use an off board charger and plug it into the joystick 3 prong plug receptacle. Do not plug in the AC cord for the on-board charger at the same time. That is, do not use both chargers at the same time.
Using an off board charger is a better permanent solution. The on-board 4 Amp chargers have always been problematic and are a little hard to get at to change. The off board chargers either 5 Amp or 8 Amp have better cooling, more reliability, easier to plug in, and easier to swap out when they fail. Off board chargers are more expensive so there is a trade off.
If your U-1 batteries are about 1 1/2 years old they are due to be changed. Hope this helps.
Dec 09, 2010 | Jet 3 Ultra Power Chair
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Broken power plug in spike
if its just the thing in the center and the motherboard didnt break, it is fixable. depending on who you find to do it it could cost from 50-over 100 or so. i have someone fixing the exact same issue on a laptop for a friend right now. i had to order the dc jack from ebay so i am waiting for that right now. that only cost $3 i think. if they have the jack and know what they are doing, it can be done in a few hours. i found the guy thats working on the one for me on craigslist. you can try that. hope this helps
Apr 15, 2010 | Acer Aspire 5610-4648 Notebook
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
