Question about Kitchen Ranges
Oven Burner is giving a yellow flame
This is a new range, converted to lp. The air regulator is open all the way.
New ge range, converted to lp. oven flame is going up the sides of the oven and air shutter is all the way closed.
Posted on Nov 23, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Why does the oven burner seem to be getting too much gas?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven burner smokes
Right at the base of the burner is the air shutter and orifice. Tighten down the orifice with a good fitting wrench. then open the air shutter all the way for propane. Make sure the regulator is set for LP if this is LP and I am guessing it is. I happen to have a training video which shows how to: HERE
I have it on that page with them other interesting videos and I ain't no pc genous so you will have to find it on the page. sowwy. LOL
Feb 26, 2010 | Kitchen Ranges
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Changing to LP ... Oven flames very hi during pre heat
Convert the gas regulator to LP. Then adjust all burner orifice outlets clockwise until the correct flame height is achieved.
Aug 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Sf114pxsw1 lp conversion
On the regulator of the stove there is a knot tha you swich to propane it have the latters lp or nat.swich it to Lp. you most open the air vents on all the burners.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Converting Kenmore gas range to LP???
I just converted mine and the regulator plug was not the same as the one in the manual. It had a black plastic piece snapped into the cap that had to be turned over for LP. I unsnapped it and turned it over. I changed the nipples for the burners and they worked great. The oven orifice had to be turned all the way down (clockwise) ans the air damper opened.
When I did all this the oven still had a large yellow and blue flame. I raised the oven orifice up 2 turns and then turned it down all the way and the oven flame was perfect! The oven orifice is hard to turn so make sure that you turn it all the way down using a 1/2 inch wrench.
Sep 30, 2007 | Kitchen Ranges
Kitchen Ranges Logo
200 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
