Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
New behringer powered mixer, comes on, but doesn't hear anything.
I purshased a new powered mixer europower PMP5000, connected by the book, but not sound at all, lights comes on, but no able to hear anything. I noticed the fan don't come on when you connected, please help, thanks
  • Barry Wuthrich Mar 06, 2009
    I am getting about the same problem with a used PMH880S. I got a little sound from an RCA input source. Then it cut out. Then I turned up the 2TRN line level, and both mains came on for about 30 seconds and cut out.
    My led's show a good signal coming in, but just a very faint sound is getting through.
    I don't hear any fan either. I am wondering if there are separate fuses for the amp section and mixer section. I don't even see an external fuse access.
  • Behringer Master
  • 5,603 Answers
Fan comes on with temperature rise. Not a problem if off till you start driving speakers loud.
Make sure standby switch is up. The slide switch is up to A/B.
The main fader iis up. Your input fader(s) are up. The trim controls are up enough. Inputs are plugged to input and not the inserts.
Be careful... this unit has a lot of power and can blow speakers.
Posted on Aug 02, 2009
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Feb 12, 2014 | Behringer Europower Pmp5000 Powered Mixer...
Are behringer pmp5000 220 volt?
Yes, the SMPS handles 100 to 240 at 50 / 60hz there is not a physical switch it is automatic for world wide use.
Aug 05, 2013 | Behringer Europower Pmp5000 Powered Mixer...
Behringer PMP5000 Mixer. Connected a speakerOn cable to Output A while device was ON. Went to do the same thing on Output B and heard a spark. Turned off the mixer. Now, it will not come on. Checked the...
Chances are you've blown the output transistors. Speakon connectors cannot short out but jack connectors can and if it was not inserted properly you'll have presented a dead short to your powered mixer. In any event it is really bad idea to connect anything when it's switched on. If you're really lucky replacing the output stage (which will probably be dead short on the transistors) and re-adjusting the bias should sort you out.
Apr 08, 2017 | Behringer Europower Pmp5000 Powered Mixer...
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
HOW DO I CONNECT 2 SPEAKERS TO THE MIXER
Unpowered (passive) speakers connect to the Speakon connectors on the back of the unit. Powered speakers or amplified ones connect to the mains output L/R connectors (1/4 inch) near the upper edge of the panel.
Oct 06, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My system will not come on. I've put a new fuse in it and I still can't get it to come on?
The power supply is blown and probably one of the amp channels. Repair will be tedious. They take out from 30 to 50 dollars of components typically.
Aug 02, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
No output power
It is likely the amps have been blown. Take for repair as further use may cause further damage.
Test the mixer by plugging headphones into the main L and R outputs. Note you will hear only one side of the headphone being these are mono outputs. The level will be low, but will check that the rest of the mixer is working.
ALSO please read my tip on here regarding a hazard of speaker polarity.
Oct 10, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Car Audio & Video Logo
321 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
