Question about Canon EOS Rebel G 35mm SLR Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
My cannon 35mm EOS Rebel Film Camera is producing blank film. I have an EF 70-210mm lens on the camera, I'm using Kodak 200 speed film. When I take a picture I hear the shutter make it normal sound and the view finder is momentarily blacking out like it has always done. It's showing that it's takiing the pictures at a 4.5 f and between 350/sec to 1000/sec depending on the brightness. I have taken them in both manual focus and auto focus with the same results.
I have removed the lens from the camera and verified the shutter is opening when the shutter button is depressed. I have done it also with a manual 1 sec shutter speed to verify it works.
The partial photo was a sliver of the subject at the bottom of the film in the middle of the roll.
My digital camera stopped functioning this week also, so i totally with out a camera.
HELP!!
  • ShawnKelly May 06, 2009
    My camera is a Canon EOS Elan 100.I'm getting parrtial pictures in the middle of the roll. These are outdoor pictures and I have the camera on "auto." It used to take beautiful pictures on cloudy days, now it sporadically looks under exposed.....very dark. The camera has never been serviced.
    Scholar:
  • 95 Answers
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Posted on Nov 29, 2008
Quantaray 70~210 Lens
If your lens is a EF mount and your digital can take EF lens the answer is yes.
Cordially,
Jan 01, 2014 | Canon EOS Rebel XS 35mm SLR Camera
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Is it possible to clean the mirror on an SLR camera, specificlly a Cannon EOS Rebel G. it looks like it has a film or dirt or possibly smoke residue on it.
It can be cleaned but you must be careful and gentle. The surface is silver and is easily damaged.
1. Blow any dust off with canned air for cameras.
2. Wet, do not soak, a foam swab with camera lens cleaner.
3. Gently wipe mirror from side to side.
4. Replace swab when dirty.
5. Repeat as necessary.
6. Gently dry with dry swab.
Sep 11, 2009 | Canon EOS Rebel G 35mm SLR Camera
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Apr 09, 2009 | Canon EOS Rebel G-II 35mm SLR Camera
I have got an EOS Elan II E Film Camera (Cannon). I want to know Cannon has camera with a digital body which suits the lens attachment of EOS Elan II E.
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
Mar 10, 2009 | Canon EOS Elan IIE 35mm SLR Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Feb 14, 2008 | Canon EOS Rebel XS 35mm SLR Camera
Won't take a picture
how cold - it may be a chip problem on the 70-300 whats the lense make/model that works and lens make/model that only works when warm
Apr 13, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon EOS Rebel G 35mm SLR Camera Logo
175 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
