Question about Sony Cyber-Shot DSC-S60 Digital Camera
LCD Screen does not come on unless connected to the USB.
I cannot get my LCD to come on unless connected to a USB
    Problem Solver:
  • 7 Answers
A posssible solution is "Deleting the USB Connection". Go to the following link http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-S60&region_id=1. Under "Manuals", click on Operating Instructions". Go to the bottom of page 62 and follow those procedures for your operating system. Hope that works!
Posted on Dec 04, 2008
LCD screen displays always "LOADING" when connected to PC USB
This is a Battery Issue as the Player is only Turning On when its Connected to the Computer!
Dec 29, 2011 | Audio Players & Recorders
When I connect my dcr-sr40 through the docking station to my computer, the option to click on HDD on my camcorder never comes up, and when I try to do the Easy PC Back up it says "failed importing...
I'm sorry for the difficulties you're experiencing in connecting the Camcorder to the Computer. Please follow the below steps carefully and check if you're getting the USB Select Screen on the LCD screen.
  1. Connect the Camcorder to the Computer.
  2. Power OFF the Camcorder and switch ON after 10 seconds.
  3. Check the LCD screen to see the USB Select screen.
If the issue persists, please disconnect the Camcorder from Computer. Reset it to default settings and then connect it again.
Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
Also try connecting to a different USB port on the Computer.
Thanks for understanding. Please get back to me with the exact Operating System that you're using if you require further assistance.
Jun 20, 2011 | Sony Handycam DCR-SR40 Camcorder
Hi, My wife broke the LCD screen on a Nokia 6500 slide so now I want to copy the adressbook which is currently stored in the phone memory to the sim card or to my PC via USB, but i have to do it without...
Install the Nokia pc suite software on your computer and connect your phone via USB to it. With this application you can download contacts. You probably will have to press left top or right top button to allow access to your phone after connection.
May 02, 2011 | Nokia 6500 Slide Cellular Phone
Screen going pink/red unless nearly closed
This is due to some loose contact of your LCD Cable connection or LCD Panel cable malfunction. Reinsert LCD panel cable in proper way and check else you need to replace the LCD Panel Cable.
Feb 13, 2011 | Acer Aspire One D150-1587 Netbook
Half the screen is blackened for about a half hour...then its fine, what is causing this? How can I fix it?
First, A new TV LCD should not display malfunction. Liquid Crytaline Devices allows the program to display across the screen area, also capable of high definition alterations either user adjusted or program device alterations to suit conditions. However, three technical requirements makes achievable TV experiences. First, the connection cables to the LCD screen should be firmly fastened. Check all connection cable connections from pheriperal devices to the TV firmly fastening to prevent media seepage. Second, LCD TV screens display fliud expressions when pressure is appplied from an external scource on the Screen. Over exerting the screen with a weight should produce distorted pictures. Third, attempt to ascertain the media that is being played on the TV. For example, broken movie disk would appear distoprted on the LCD screen because is designe for sensitivity. A muttated picture displayed on the LCD screen usually is tracable elsewhere to connection devices orpheriperals. Brand New LCD TVs are expected to least malfunction unless were physically damaged. Goodluck
Jan 08, 2011 | Vizio VO47L 47 in. LCD TV
When i switch it on the lcd screen foes not come
Hi I am vortash one of the big problems with digital cameras especially the type that the screen folds out like the one depicted in this picture , is that the Plastic and copper ribbon that connects the screen to the circuit is prone to cracking and breaking hence no picture on the lcd .
So the only alternative unless you can do it yourself ( and this is not advisable unless you dont mind if you muck it up lol ) is to take it to a local engineer for repair , or return it to the manufacturers for a quote on repair .. regards Vortash
Mar 30, 2010 | JVC GR-D60 Mini DV Digital Camcorder
Automatic test page
Work through the menu-items on the printer's LCD screen -- it's an option that you can enable/disable.
Jan 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
Wont usb connect!
go into device manager and update the drivers on the newly found hardware. If they are already installed used the disc to re-install from device manager.
Then add the application on whilst the item is discomnnected
Re-connect and launch application. Should work.
Dec 24, 2008 | Logitech Harmony 525 LCD Remote Control
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
Sony Cyber-Shot DSC-S60 Digital Camera Logo
42 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
