Question about Beko Dishwashers
Beko DWD4310W, when I start the wash cycle it trips the mains socket central trip
  • 9 Answers
SOURCE: tripping out
Oh oh. Most probably you have an ( electrical ) earth-leak in your dishwasher.(DW) In many cases this happens when the liquid in your DW must be heated. This heating is done by a resistor which you can see in the bottom of your DW ( a tube ).When heating up some liquid will get thru minor metal cracks in the outer resistance tube causing a path able to conduct some "leak"-current to the earth, and cause the the "differential" circuit breaker to switch off all current supply in house. ( Thanks it exist and works, it saved many lives) Best is to ask a repair-service to do the job; this can be done at your home.At the same time they have to check the thermal protection in the DW. If the resistor is not the failure, the electrical leak can come from other locations in the DW ; an isolation failure within the cabling or around the pump. It is not always evident to trace such an electrical leak, a repair service normally use a Megger ( this is real British ) to trace. Hopefully you don't have to manual dishwash too long.
Posted on Nov 07, 2006
zeusfaber
  • 247 Answers
SOURCE: My dishwasher is tripping the electric.
Usually time to replace the heating element. The element is sealed inside a metal tube packed with a dry powder to insulate it. If the outer tube leaks (and it only takes a pinhole), the powder gets wet and stops insulating. It only takes a tiny earth leak to take modern trips out. If your dishwasher is one of those where the element is visible in the bottom of the compartment you load the dishes into, replacing it yourself ought to be straightforward. If it's buried in the works, whether you want to tackle it yourself or pay someone else to do it depends on how confident you are. Either way, it shouldn't be catastrophically expensive. A.
Posted on Mar 04, 2007
  • 883 Answers
SOURCE: my dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Posted on Jun 05, 2007
colin324
  • 57 Answers
SOURCE: washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
Posted on Nov 20, 2007
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
Washer trips mains fuse when started
There's a short-circuit in the washing machine, possibly in the heating element.
Feb 11, 2015 | Beko Washing Machines
Tripping during was cycle
Wash motor does not run during dry cycle. Wash pump motor pulling too much current. May need to replace motor.
Apr 30, 2014 | Beko Dishwashers
Beko eco care is tripping after about 1 minute into a wash
I think it could be the motor or the circuit board
Mar 24, 2013 | Washing Machines
I have a beko wm5100w washing machine and it keeps tripping the electricity
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Nov 25, 2010 | Washing Machines
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine tripped all sockets halfway through cycle
Hi.
You are going to have find the problem by elimination.
Start by unplugging the motor. and trying it again,if it still does it then you need to disconnect heater and so on, until it stops tripping
Nov 24, 2008 | Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Washing machine
Oct 07, 2007 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
60 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
