Question about GE Spectra JBP78 Electric Kitchen Range
GE range JBP78G
I have arange oven?clock control which has "EEEE" on it and nothing that I do will change it. Tried to reset it and shut of power. Range top burners work ok. oven or clock won't. It has the Wb27x5581 controler . Thanks
  • Anonymous Mar 31, 2014
    The only thing that seems to be working is the Clock. No burners, no oven. The 220v is working just fine. Is there a master internal capasitor\breaker that may need replacing or resetting?
  • 100 Answers
There are no known errors like that for the control so i am thinking the control is damaged.
Posted on Oct 30, 2007
SOURCE:
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Tried to change the oven light bulb and when I took it out it said poof and now the whole range is dead. Electricity is going to the unit, but nothing works... not even the clock. Is it gone or maybe...
The first thing I would check, considering you've confirmed there's power at the outlet the oven is plugged into, unplug it. Next, remove the metal panel that is behind the "head," (behind the clock and the controls.) Look for a blown fuse on the circuit board in there. Chances are, that may be all that is wrong. At least it's a cheap fix, and your local Radio Shack should have a replacement fuse for you.
I hope this helps! :)
Dec 16, 2010 | GE 30" Self-Cleaning Freestanding Electric...
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Jul 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
GE Range Spectra oven not working
F2 is an indication of an oven temperature sensor problem. Usually this is a problem with the oven sensor itself, or the relay contacts on the Electronic Range Control (ERC) board. If you had a close lightening strike, I would suspect that the contacts on the ERC are probably bad. It probably wouldn't hurt to replace the oven sensor as well. I hope this helps you.
Jun 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
197 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
