Question about HP Computers & Internet
My computer it's not reading the cd or dvd and when I go to computer option I don't see the drive E
  • amneros17 Nov 24, 2008
    You are telling me that drive E, is dead and the best solution is get a new cd with the program at best buy, and some one there can instol the program?
    My computer is a PresarioCQ50-139WM a week old.
    If you have another solution please let me know.
    Carlos R,
    Sergeant:
  • 207 Answers
Hi Amneros,
start up your computer and while the compaq logo is on the screen push the <Delete> key 3 times. This will take you into the BIOS (Basic Input Output System) for you PC on the first screen that pops up there should be a listing for IDE there should be two entrys there one for your hard drive and one for your CD/DVD. Some laptops come with CD/DVD units that can be ejected and replaced. If this is one then perhaps its connection isn't quite tight enough. eject and reinsert the drive and check it again. However with this unit being just a week old, if the CD/DVD isn't "Swappable" and you don't see it in bios, take the unit back to the place where you purchased it and they should have service techs that can repair your problem without voiding your warranty (Warning: this may mean you'll be without your PC for a day or two)
Now press <F12> to exit out of your bios and restart. Assuming you found an entry. Boot into Windows and go into device manager (Press <Windows> key and <Pause break> at the same time. Then select device manager, right click the top listing and select "Scan for changes" This should force the system to check for software that it hadn't previously setup.
If this doesn't get you the results that you seek please comment back here and I will do my best to get you up and goin again.
Thanks for your consideration,
Dave
Posted on Nov 24, 2008
  • HP Master
  • 4,806 Answers
No the drive is not dead, its the operating system, and this could be a number of reasons, bad registry entries etc, i need to know what operating system you are using to navigate you through the process or processes
regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 24, 2008
    well i'm guessing its vista, so, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the DVD/CD icon and unistall it, reboot the pc and let the operating system detect the drive and install the drivers for you, i hope that this way will work for you as i have come accross this problem before with vista, xp and 2000 and i know a few "tricks" to sort the problem out
    regards
  • Lee Hodgson
    drive not icon sorry
  • Lee Hodgson
    i doubt the this is a hardware issue but rather software/driver issue
  • 4,472 Answers
Most likely the drive is now dead. You can purchase a replacement for quite cheap either online at places like tigerdirect.com or you can go to your local best buy, where you can also have it installed by geek squad for a fee. You can check the connection but usually connections dont become loose on desktops. If you have any other questions please let me know. Also what is the model of the computer I can locate an example of a replacement. most likely you will want a IDE drive. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Nov 23, 2008
  • Lee A.
    Lee A. Nov 24, 2008
    If the computer is only a week old then you will want to take it back to the place where you purchased it as this should not occur with a new computer. There is no reason to mess around with someone that can be returned under a return policy. Normally anyone would not assume the computer to be a week old. Where did you purchase the computer? It should be quite easy to either have them fix it for you, or replace it for a new one. If you need further assistance please let me know. Please reconsider your rating and accept and rate my solution accordingly.
    Thanks again,
    lee
  • Lee A.
    Lee A. Nov 24, 2008
    No I am not recommending you get a new cd with the program. I am recommending it probably needs a whole new cd-rom/dvd-rom drive. That or it has a bad connection either way if it is this new of a computer returning it for a new one of the same model is more then appropriate for the situation.
    Thank you,
    lee
Is there a external CD Rom drive for a HP Pavillion a1410y desktop computer
Why not just replace the CD drive in the PC? Don't be afraid to pull the cover.Turn the PC off,but leave it plugged in(the grounded plug will prevent static damage).Disconnect the drive,pull it out,put in a new one.(Don't forget to match the option pins on the back of the drive to set it for "slave" or "master".
Sep 07, 2012 | HP Computers & Internet
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
My laptop getting slow and slow.. how do i reformat my computer??
Just get an Operating System CD/DVD, you want to format with, place it in your CD/DVD drive and make a computer reboot. When the computer will restart, during the pre-booting process, it will show "Press any key to boot from CD/DVD". Now press any key to start the formatting process (But before that, be sure, you have CD/DVD boot option ON in the BIOS settings).
Now follow the on-screen instructions. That's all.
For more details how to format Windows 7 from CD/DVD, read this section: http://howtoformatacomputer.com/format-windows-7
If you are willing to format Windows 7 from USB Drives, you may want to read this section: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
NOTE: If booting from CD/DVD is disabled in your BIOS and you don't know how to enable it, please let us know by commenting over this reply.
Hope this helps, Mrityunjay
Jun 19, 2012 | Samsung N150 (36725723009) Netbook
I don't know how to download cd's and dvd's on dell EL-1210-09
What do you mean download cd's and dvd's? You don't download them, you simply put them in the drive and play them. If you purchased a music cd or a movie dvd that you want to play or watch, then just put it in the drive. The system will recognize it and automatically open Windows Media Player for you to play it or you can open it yourself if autoplay is not active.
Exactly what is it that you are trying to do?
If you are talking about putting a blank cd or dvd into the drive to copy music or a movie to it, that's another story and will take a while to explain. You will basically need to make sure your CD/DvD drive can burn CD's or Dvd's. Then you will need some type of burning software (later versions of Window Media Player will burn).
Click Start/My Computer and look at your devices. if your DvD/CD Drive is listed look for RW which means rewritable (it can burn or copy). If it say DVDrw it can read and write dvd's. If it says CDrw it can read and write cd's. You can also look on the drive door on the computer where you would place the cd or dvd. If it says Rewritable CDrw (it can write cd's) or DvDrw (it can write dvd's). If it says ROM (read only media), that means it can Read Only and not write.
If the drive is rewritable then the software such as Media Player will allow you to go find what you want to put on the cd or dvd. You have two ways of putting things in the software to burn or write. You can copy and paste, or you can drag and drop.
May 13, 2012 | eMachines EL1210-09 PC Desktop
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Nov 30, 2011 | HP Computers & Internet
My DVD writer is not able to read and write dvd's again within a year & now i don't have bill . What will I do ?.
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 07, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
My DVD Ram drive is not reading any CD/DVD
The most common reasons for a power calibration error is a dirty lens or bad media. Clean the lens with a short burst of cabbed air or carefully wipe it with a cotton swab.
Good luck.
Mar 17, 2009 | Microsoft Windows Vista Business DVD...
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP dv4000 laptop CD not reading
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 23, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
13 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
