Question about Fujitsu Plasmavision PDS-4233 42 in. Television
Screen goes off repeatedly
I have a 5-year old Fujitsu 42" Plasmavision. It will often go dark, and the red light start to flash. I tried unplugging it, and I heard some kind of relay trip after a couple of seconds. I plugged it back in, hear the relay or whatever reset twice, then turn on the TV, and it works. Sometimes that's it, other times, I go through this 5 or 10 times. Power is from the NYC grid, smooth and constant.
Any ideas?
  • mikeoffit Nov 23, 2008
    Thanks! I figured it was something in that neighborhood... is it possible that as the TV gets warm fromrunning the board functions better? Seems wierd. These days, might be cheaper to buy a new TV!
  • Fujitsu Master
  • 19,396 Answers
Often you get this kind of problems when one of the sustain boards is faulty, the TV must be tested .
Posted on Nov 23, 2008
  • Ginko
    Ginko Nov 23, 2008
    If the picture goes dark then one of the sustain boards is defective.
    the technician must perform 3 test on a Sus board, test an on board fuse/resistor, test an IC and test the board voltages, this is not a job for a beginner.
    You can try doing it yourself, at your risk, in this case you replace the whole Ysus Zsus Kit without testing, relying on the fact that intermittent dark picture is usually symptom of a faulty sustain board.
    The best option is probably calling the phone number listed on the owner manual and asking the cost of a repair or contacting a local repairer and mentioning the dark picture, he will surely address the Sus boards.
  • Ginko
    Ginko Nov 23, 2008
    More on your problem, the kind of relay trip after a couple of seconds is a protection switch that is activated when a fault is detected.
    By leaving the TV unplugged you drain power completely, and the defective component restart working, until it fails again.
    Try leaving TV unplugged for longer and see if this can sort out the problem. If not follow the indications given on previous comment and get it repaired.
Is 9 year old Fujitsu Plasmavision TV worth fixing?
Hi
Can i please know yout TV model number to assist you better.
Thanx
Jul 22, 2010 | Fujitsu Plasmavision 42" TV
My display keeps shutting off five minutes after starting to watch TV- the sound continues, but the screen is black and the red warning light flashes
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
Thanx
Jul 02, 2010 | Fujitsu Plasmavision 42" TV
Picture goes out and red power light flashes
Up , i also encountered the same problem 3 days ago. 42" Fujitsu Plasmavission. I'll try to call an expert, i hope its not a digital board again for me, it will cost around $2,000usd so better buy a new Korean made LCD for better and cheaper parts. I guess you also experiencing trmendous heat at the back of your plasma right?
Dec 19, 2009 | Fujitsu Plasmavision 42" TV
Is my Fujitsu Plasmavision "dying"? Same problem
See Fixya Tip and Tricks 'Fujitsu P42HHA30ES 42 in'.
This is a common problem with these models.
Information provided should enable problem to be readily repaired at minimum cost.
Flashing red is an alarm code from the processor only. Indicates a monitored fault by the processor - is of no danger of causing further damage.
Aug 23, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu Plasmavision PDS-4233 42 in. Television Logo
74 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
