Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
How to lock blade on older circular saw
How to remove blade from Sears circular saw. There does not seem to be any kind of lock button. I don't have a manual.
  • maude22070 Nov 25, 2008
    Thank you -- will try. Sounds right. Had been looking for a lock button.
    Sergeant:
  • 359 Answers
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Posted on Nov 24, 2008
Circular saw locking bolt turns spindle
There is a button on the saw that holds the shaft still. Unplug the saw and put light pressure on this button while you slowly turn thr blade by hand. When it gets to the hole, the button will drop into the shaft. Keep it pressed down and unbolt the nut.
Jan 12, 2015 | Saws
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
I can't find the blade lock used to remove my old blade. My model # is sears 315.108230
There should be a small black button on the right side of hand grip. You can also use a small block of wood between the blade teeth and the shoe to hold the blade in place while you loosen the blade nut.
Oct 31, 2010 | Sears Saws
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Oct 02, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Instructions to install blade on circular saw
Once you have the right size blade it is really simple to change it.
You only really need two things.
1. locate the button that locks the spindle. It is usually located on the body of the saw. Your manual can show you a picture of it.
2. You will need a 3/8 drive socket that fits the spindle bolt.
I believe these are standard thread orientation and come off counterclockwise.
Mar 20, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Jan 31, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
Replacing saw blade
there is a spindle lock button between the handle and the blade housing, rotate the blade by hand while pushing in on the lock buttonwhen it goes in all the way the blade will be locked in position so you can loosen the bolt with a wrench
Mar 31, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
251 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
