Question about Panasonic PT-47WX49 47" Rear Projection Television
Blue Convergence out of sync
So my tv was working just fine up until yesterday morning. When I turned it off 2 days ago everything was fine. When we turned it on yesterday morning the blue convergence was completely out of sync with the rest of the tv picture. I've read a few post on here about replacing the convergence IC's. Unfortunately I am not familiar with any type of internal TV repair and was wondering how complicated of a procedure it is? It seems that the parts aren't very expensive(including the soldering kit) but having a professional come in and fix my tv is going to be around $300 which is how much I actually spent for my tv. Any feedback would be much appreciated
  • 3 more comments
  • Albert_C Nov 23, 2008
    This is a picture of the screen and the problem that's going on with it. Thanks again!
  • Albert_C Dec 10, 2008
    I spent over an hour trying to get the convergence down and it doesn't seem to be it. After doing some research it seems that logically what's wrong is the convergence IC's.
  • teresah786 Dec 20, 2008
    i have a pt-47wx49 rear projection    the blue is off on screen when following guide convergence1  convergence 2 the blue will not directly line up behind white it moves so far then the blue starts doubling tripling if i keep trying to force a line up .under convergence2..any suggestion     teresah786@gmail.com
  • Anonymous Dec 21, 2008
    Blue convergence is off. Happened overnight. Dec 20, 2008
    Blue convergence is off. Happened overnight. Dec 20,2008. No solution yet.
  • 3 Answers
You need to adjust the convergence. you set up convergence 1 then 2. follow the manual. (Its easy, you just align the + signs so they make one white one (instead of three green, red, blue) sounds like something or someone bumped the tv, causing the blue lens to shift a little.
Posted on Nov 24, 2008
How come I can get Netflix on 1 tv and not the 2nd tv I worked fine until yesterday it stopped on the 2nd tv but other sites work on it
Start by troubleshooting whether your second tv has an appropriate internet connection. I have found that with multiple devices connecting to the same NETFLIX account, often has intermittent connectivity problems attributed to the device connection to the internet.
Oct 27, 2014 | Roku 2 XD Streaming Player 1080p
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
Picture now has alot of yellow and blue shadowing
Ur tv have convergence problems,it dead.Require 2 STK convergence ICS and some or all it resistors replaced on the convergence board.The shop will cost u $300-350 for parts and labors.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Toshiba 50H72 Rear Projection Television
You will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link and they will provide free instalation instructions with pics and also free on line tech support so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba 50H82 50" Rear Projection...
43FDX10B working Great until Time Warner installed cable box
try connecting the box to a different input
also try connecting another device (like a VCR) in place of the box to see if the problem exists without the cable box
Jan 13, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
