Question about Carrier 52PQ307 Wall/Window Air Conditioner
Burners wont ignite
I have an older carrier packaged unit model #585H, AC worked well all summer turned on heater for fiost time this year , fan is working but no heat. i removed the panel and started the furnance again and the pilot light will lite for about 20/30 seconds then goes out , burners do not ignite electronic starter is ticking. any ideas?
Any help is appreciated
My unit is a roof mount if it matters
  • denofriopain Nov 24, 2008
    well !! i don't want to sound tooo stupid Jeff but i don,t know if it does or not. I looked thruogh the replacement parts list and i don't see on. Thanks for your time
    Sergeant:
  • 359 Answers
Does unit have thermo-cupling
Posted on Nov 24, 2008
  • Allen Neal
    Allen Neal Nov 24, 2008
    if it has one ,the flame of the pilot flame would be burning right against it ,or it has a smart -valve in which case it could have a bad valve(NOTE).something in the unit has to see the pilot is lit and send a message to the gas valve that it is ok to open
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
Uh1200-fsp---pilot lit main burners wont ignite,fan runs,has new thermocoupler????
If you installed the new thermocouple, you may have overtightened it. It should be installed finger tight and only a quarter turn more. If it's to tight it won't allow the gas valve to open to light the burners. Be sure to turn the gas off, before attempting to work on the unit.
Feb 02, 2011 | Empire Heating & Cooling
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Question on a day and night gas forced air heater
it very well sounds like your fan switch , does your fan work at all, like in ac mode on by turning the fan on/auto switch on the thermostat to ON. If the fan does come on its the more and likely the limit switch. if it doesnt come on it could be the motor or the run capacitor. the limit switch has a dial on it that as it heats up it spins clicking on at a desired set temp ussually about 120 to 150 degrees F. turning on the fan if the fan doen't come in the the next setting clicks off the gas valve turning off the burners ussually set at about 220 degrees F. now if the fan is working when the heater is satisfied there is a setting at about 90 deegrees F. that shuts the fan off hope this helps
Jan 05, 2009 | Honeywell L4064B2236 Fan/Limit Control...
CARRIER HEATER FAN WONT TURN OFF. PLEASE HELP
Need more information.... Is this a whole house unit, a window unit or what? Model #?
The breaker would be in your basement or wherever your breaker box is. If it's a 220 unit, one side could be kicked if whoever hooked it up used 2 seperate breakers (very unusual but it's been done).
Geno
Mar 06, 2008 | Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Carrier 52PQ307 Wall/Window Air Conditioner Logo
264 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
