Question about RCA F32649 32" TV
Video Input How do I get the video and audio inputs at the front of the TV to work? There are only two video input channels the video for dvd and the s-video input. I just purchased Tivo and connected it to the back of the TV which uses the DVD input. However, now I cannot access the DVD player. Help!!
  • Anonymous Mar 17, 2014
    Need to change input on Panasonic TV to HDMI. All inputs show blue and HDMI, HDM2, and Video 1 are in grey and I cannot click on the grey input/s that I want?
If your remote has a WHO*INPUT buton, that should allow you to select the front input.
Posted on Jan 29, 2007
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
How do i get to the channel to watch a dvd
You will need to connect the video and audio from your DVD to the Input of the TV. So use a RCA cord to connect from the video output /audio output of the DVD player to the AV/Input/video input/audio input of the TV. Now use your remote to select the AV channel and your video and sound will come. Do this carefully . Hope you try. Good day
Aug 13, 2010 | Zenith B27A11Z 27" TV
No auxillery channel
your unit is equipt with audio video input jacks. It is located in front of the tv, right lower side. this is a video in and audio input for your dvd player.
Apr 11, 2009 | Sanyo DS19310 19" TV
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
RCA F32649 32" TV Logo
893 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
