Question about Mitsubishi WS-55857 55" Rear Projection Television
The power light just keeps blinking.
Tv worked fine,
    Problem Solver:
  • 7 Answers
Change the four caps in the dm module.
Posted on Jan 14, 2009
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
TV shuts down with Red Light blinking
it must be your tv was heated on long usage.
sir, try to go to your nearest expert technician. they have tools to use on fixing your tv's hardware. or see if your tv has a warranty to send it back to the place what youve bought it. hope that helps!
CHARCOIS
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Lite in the front of the TV when you turn on keeps blinking and no picture.
Q510, Ta1316 is your sync processor and probably the problem you're having here. It's a common one for this unit and you could pull the board and check the solder connections it has with the foil - - but you may need to replace it...
Nov 05, 2007 | Toshiba 50H81 50" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
