Question about Ruud UBHC Air Conditioner
I have a Ruud thermostat want to change to totaline p274-0200-c
Heat pump unit a/c heat emerc heat where does the wires go
old unit is as
blue wire =O
white wire =X
red wire =R
white wire=E with jumper to W2
green wire =G
yellow wire=Y
New stat
S1
S2
O/W2/B
R
C
Y/Y2
G
W/W1
Thanks for your help
Posted on Nov 25, 2008
    Sergeant:
  • 359 Answers
What are the choices on the new t-stat need to know that first
Posted on Nov 24, 2008
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
Have 3 ton elec a/c and heat - heat is on and air is blowing cold, unit is new (15 mos) home 1350 sf - breakers are OK, filter is clean - what can you tell me?
If its not a heat pump- check the white wire connection on the thermostat. If it IS a heat pump, check the blue wire connection on the thermostat. Both of these wires control the heat in their respective systems.
Jan 26, 2011 | Ruud UAMB042 Air Conditioner
Need order of wire color for heat pump
Control Panel R-Red to R at Thermostat
Jan 26, 2010 | Ruud UBHC Air Conditioner
Trouble Wiring in Rheem heat pump
The red wire goes back to the furnace red, the blue back to the thermostat blue, the brown back to the furnace C terminal, the yellow back to thermostat Yellow (if there is a Y terminal on that furnace, land your Y's there. The purple wire outside comes back and ties to the W terminal on the furnace. Now you have a dual fuel unit so you will need a dual fuel kit or a thermostat that has dual fuel capability along with an outdoor sensor.
Jul 02, 2009 | Ruud UBHC Air Conditioner
I need help with my central heat and air unit, it has a heat pump. the model number is GQ3RA-036K. I am changing the theromstat out and the wires are connected to it. there are eight wire colors that are...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
May 07, 2009 | Heating & Cooling
I'm COLD!
Any will work provided you have it is a Heat Pump thermostat. I recommend honeywell or totaline.
Dec 05, 2008 | Ruud UBHC Air Conditioner
Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Jun 14, 2008 | Ruud UBHC Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Ruud UBHC Air Conditioner Logo
366 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
