SanDisk Sansa m200 (2 GB) MP3 Player Logo
Elizabeth Benson Posted on Dec 29, 2006
My MP3 player will come on, but you can't get to the menu to select any options. It hasn't been drop, it was working fine and then it wouldn't work.
  • kiopeaches Jun 09, 2008
    My MP3is actually a 1.0GB and it get stuck on SANSA m240 1.0GB and really need to fix it.
A
Anonymous
Damn Sansa piece of junk. 1 week, not mistreated at all and it just won't go past the menu screen. Now I find that everyone else has the same problem. I think the best solution would be to collect them all for the purposes of a Mass enema for the Sansa president.
A
Anonymous
I got stuck with the same lemon. It goes to the sansa page and sticks and i have to take the battery out to get it to shut down. Purchased: Christmas, Dead after excellent care: 3.5 months.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 26, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
109
Points
Does anyone know how to go about taking advantage of the 1 year warranty? Mine turns on fine, but gets stuck on the screen with the sansa logo, when I plug it into a computer it does not even recognize it as a drive. I want to retutn it because I think it may be fried or something.
  • Anonymous Apr 26, 2007
    Does anybody know the steps in order to take advantage of the 1 year warranty. I've had my player for a few months and it turns on fine, but it gets stuck on the screen with the sansa logo and I can't get into my music files and I have to remove the battery in order to turn the player off. Please let me know if anybody actually returned their player for a new one or their money back.
Anonymous
Level 1:
  • Posted on Jan 09, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
109
Points
My MP3is actually a 1.0GB and it get stuck on SANSA m240 1.0GB and really need to fix it is there anyway i can fix it with out taking it bac to the shaop
A
Anonymous
No i have'nt found a solution yet
A
Anonymous
Hi lilsweetie did u figure out the problem and how to fix it my daughters did the same thing let me no thanks [email protected]
1helpful
It is not going to sync music on to it
Try Draging and Dropping the music and files:
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
3helpful
My lap top does not recognize my sony mp3 player. it's the first time this happens. i just installed the 30 days free norton 360 anivirus version so the limewire program and i also installed and...
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box:
1. "devmgmt.msc" Click OK.
2. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
3. Choose the "Scan for hardware changes" option from the drop down menu that appears.
4. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
1helpful
I need to find an installation program to switch my zen nano to vista from xp
try here first and if that doesn't work you should be able to load it using the drag and drop method
support.creative.com/kb/ShowArticle.aspx?sid=14186
heres the drag and drop/windows media player options
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
1helpful
My computer is saying my mp3 player is not plugged in but ut is. it had no problems before.
Try checking the driver and seeing if it is working right. Here is how you do that:
3. "devmgmt.msc" Click OK.
4. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
5. Choose the "Scan for hardware changes" option from the drop down menu that appears.
6. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
1helpful
Mp3 player will not conect to computer
1helpful
80gb Classic backlight on, no menu displayed
you LCD is Broken...Look for an iPod Repair in your area and have the LCD replaced.
it's a classic symptom of a damaged LCD..I see it all the time.
10helpful
5answers
I got a missil gl-1502 for xmas,the manual isn't that good.It doesn't te me how to load music on to it.I have been trying to load for acouple of days.I have music loaded on to my computer but can't get it...
These made in China MP4 players are quite budget ... however,I've managed to get mine working just fine. Just follow these steps:
1.Charge the unit. (These things come with a dead power supply, soyou'llhave to to charge it with the provided USB cable... or any cable such asone that works with a camera. you'll not be able to load it orturn iton until this has been done. 3 hours later your computer willdetect newhardware (USB mass storage device) and install the appropriate drivers.
2. Loading MP3's... there are 2 ways to go about this...
a) If you have the latest Windows media player click on the SYNC tab and follow the directions.
b)Open "My Computer" you should be able to see a new drive (probably E: F:or G:) double click to expand it, you should see a bunch of folders,simply drag and drop your MP3s to the Music folder.
3.Converting and Loading Video: The included program that comes withthesecheap-*** players is a bag of $#@! so dont even bother with it.
The best program to convert videos to work on this thing can be found HERE
-Pick the first one (note:this file is zipped so will need to extract it),
pick up a trial version of WinRar HERE
-Once extracted, go ahead and run the program...click ADD
Choose your input file, and output path,
Youwill need to know the resolution of your screen. Under Playertype,choose SUNPLUS AVI and select the video resolution of your Missil, 30frames/sec and the best sound/video quality and hit start.
- this process takes a while (30-60 min) depending on file size.
- Once complete, simply drag and drop (cut and paste) the converted file to to the VIDEO folder on the players drive.
3.Finally disconnect the player from the computer, it will say"pleasewait.. building playlist" once this is done you're good to go
I hope this has been helpful... and please... dont forget to rate this solution.
Jermzii
4helpful
3answers
MP3 player won't turn on
mine usually turns on the next day
2answers
Graig MP3 problem
will not connect to PC
When i tried to format the mp3 it it works on the comp but then when i diconnect the usb it just says format error
Try using the format option on the mp3 itself. Hold the "menu" button, scroll through the options to the "advanced menu". Select it n select format. It worked for me.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
