Question about Kenmore 57029 Side by Side Refrigerator
How to locate the water filter
Slow flow on the water dispenser
  • 3 Answers
Be sure to turn off the water valve before you start.
The water tube is probably kinked at the front lower left corner. Take the front lower grill off of the refrigerator and open the left door (freezer) and see if the translucent plastic tube is kinked where it comes from the bottom of the refrigerator and goes up into the door.
If it is, there is plenty of tubing to allow you to pull it out of the connector at the corner and cut off the kinked part and re-insert the tube.
Turn the water valve back on.
(This was the problem with my fridge and I had to show the Sears technician.  He had already told me to call a plumber and get a dedicated water line due to low water pressure!  Imagine the cost if I had believed him.  Works great - good flow and no leaks.)
Hope this helps.
Posted on Dec 22, 2008
Water dispenser is not working
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
MY SIDE BY SIDE Whirlpool dispenser water is slow
A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.Thanks.
Feb 04, 2011 | Whirlpool ED2FHGX Side by Side...
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
