Question about GE 46GW 948 46" Rear Projection Television
No power/ clicks 5 times.( At wics end!!!!!!!)
When I push the power button I can hear a clicking sound.It clicks about 5 times then nothing. I have replaced the HOT transistor, 4 capacitors, & a diode on the power board. I still can't get any picture or sound.
    Sergeant:
  • 308 Answers
I would suspect either the High voltage distribution block and/or the high voltage transformer as being at the root of your problem, especially with the HOT transistor being bad. If this set went out during a power surge/lightening storm however, all bets are off.
Posted on Dec 29, 2006
My sony theater system dav-dz310 is waking but no sound. Even l connect the HDMI cable the video is coming but still no sound
Try this and let me know. First unplug the unit. Plug it back in. When you first push the power button, you should hear 1 click followed by another withing 5-20 seconds. My guess is that you don't hear the second click. Am I right?
Aug 06, 2015 | Sony Audio Players & Recorders
Receiver doesn't play sound until it's warmed up 5 - 10 minutes
Unfortunately, your question has too many variables. Try this. Unplug the unit. Plug it back in. When you first push the power button, you should immediately hear one mechanical click from the unit, followed by a second click with 5-10 seconds. If you don't hear the second click, the unit may have a condition known as DC Offset. It would be unusual to have DC Offset only within the first 5-10 minutes. It's possible that power supply has an issue where both the positive and negative voltages are not coming up at the same time.
If you are interested in having your RCA repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 22, 2015 | RCA RT2500 System
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
On my Kenwood vr-505 Under the speaker symbol it says clip and there is no sound coming from the speakers
Hello. My name is Dave. Unplug the receiver. Plug it back in. When you first push the power button, you should hear one relay click. Within about 5 seconds, you should hear another click. My guess is, you don't hear the second click. Am I correct?
Dave
Sep 30, 2012 | Audio Players & Recorders
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Samsung HCN4226W 42 in. Rear Projection
My 5 year old Samsung HCN4226W is not coming on (no picture and no sound). When pressing the "ON" button, I can hear a "click" like it wants to come on, but nothing happens. HEL
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
75 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
