Question about Logitech X-230 Computer Speakers
Logitech x230 speakers
I recently purchased new logitech x 230 speakers for my HP computer to find that the system didnt recognise them at all, in control panel "speakers and audio devices" says NO AUDIO DEVICE I don't know what to do.
Reinstall sound card drivers.
Posted on Feb 16, 2007
Broken green pin on logitech x230 can this be replaced
if the green pin is what plugs into your computer, a traditional, headphone 1/8th inch headphone jack, it can be replaced, however there is some soldering involved. Radio shack sells the replaceable ends for just a couple dollars. the only problem is knowing which wires to connect to which points on the new end. i would have to see the wire with the insulation stripped off to be able to tell you which are which
Oct 18, 2012 | Logitech X-230 Computer Speakers
How do i connect my logic speakers x230 to my pc with windows xp
Connect 3.5 mm Jack to the Line out port & get connected your speakers to PC.
Thanks.
Happy to help you.
Apr 24, 2010 | Logitech X-230 Computer Speakers
Im trying to install Logitech x230 (windows 7). Have folowed all the instructions but there is no sound. I get a pop up and have to choose between line in, etc..which do I choose? Thanks
Please find or download logitech installer in your PC . Check also the pin connection of your hardware at the back of the CPU usually the phone jack there is lighth green.
Jan 28, 2010 | Logitech X-230 Computer Speakers
Tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Jan 10, 2010 | Logitech X-230 Computer Speakers
My x230 wont work it work for a min then cut out and dont work!!!
Try and twist the jack which is connected to your PC, the solder inside could have snapped. If it has a diferent pwer source for the sound system, then power on, hold the jack and short the ends with your fingertips. If the speakers dont respond then its not getting any power, which could be simple loose connection too. Test both and then decide. If you dont have the correct driver then download from: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q........sodeep
Feb 23, 2009 | Logitech X-230 Computer Speakers
Logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Nov 18, 2008 | Logitech X-530 Computer Speakers
X230 logitech not working.
i did the same to mine,
just replace the power transformer with one that accepts 110-240 volts
easy to do, but check cost might be better to buy a new set depends on your situation
Aug 20, 2008 | Logitech X-230 Computer Speakers
Service Manual for X-230
I used a Radio Shack D-Sub 9 Pin Connector #276-1427
Pin 1-Empty Pin 2-Purple Pin3-Yellow Pin4-Red Pin5-Shield Wire & Green
Pin6 & Pin7-Gray Pin8-Blue & Black Pin9-Brown
The pin numbers are on the face of the connector and are hard to see.
Feb 17, 2008 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
372 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
