Timers
Problem for Timers
Generic problem for all Timers
Need instructions for a Timex Timer Mod...
By jimbo55z on Nov 23, 2008
need instructions for a Timex Timer Moder #TE111 (TX12694TA)
Same Problem
May 18, 2009
-   I can set the clock, but can't seem to program it to go on and off at times I've put in. It will only turn on when in the on mode, never in the auto mode.... or it won't turn off -   Guest
Dec 10, 2008
-   Need instructions for setting the correct timer- on/ off modes. -   jkeljik
Dec 01, 2008
-   i need the instructions as well..... -   Guest
Best Solution
posted on Dec 19, 2008
Very Helpful)
audiodave1
Rank: Apprentice
Rating: 100%, 12 votes
To set the timehold down the TIM button until Day flashes, Use +/- to adjust then hold down time until hour flashes..Repeat until set.
To program,
1. hold down prog until the cursor starts to flash at 12:00
2. Press PROG to advance to the day or day group you want to program.
3. press + to advance the cursor to the desired ON time
4. press mode until display reads "on"
5. use the + to move the cursor to the desired ON duration? Clock shows this also.
6. press mode until "off" is displayed. then advance the cursor thru the period the outlet should be off. (stupid to have to do this!)
7. press MODE to select as the ON or OFF period(!)
8. press TIME to exit programming.
9. Press PROG again to program another set of days.
Stupid system.
Good luck.
Dave
Was this helpful?
Yes
No
12 people thought this was helpful
Popular Solutions for Timers
Questions and Unsolved Problems for Timers
Answer
I need assistance on programming a Holiday living Model LW28080 outdoor stake timer
Answer
hammering while grundfos comfort system is pumping
Answer
replaced timer, burned out, and the new one burned out as well. i connected the black to the black... (More)
Answer
need a manual for a hb300rcl ,lost the manual can not set up
Answer
Which tripper pins are required for Paragpm Timer Model 7218 and where can I purchase them?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Timers:
Top Timer Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Timer Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
