Question about Panasonic NV-GS11B Mini DV Digital Camcorder
Tape loading mechanism initialisation error [NV-GS11eg]
Hi, the problem is in the tape loading mechanism so when I put the camcorder "ON" the tape try to eject even the door closed, and the message "press reset button" appear and if I open it then put "on" it will eject and load infinitely even no tape in. the only way to operate the cam is to insert a tape, close the door, let it try to eject (with the door closed), so when the message "press reset button" appear I press reset then record few seconds and the camcord is ready for the session, but the problem reappear after power off-on but this is just a trick I have discovered. so how to fix this problem, at seems the camcorder did not recognise if a tape is in or not thanks
  • 1 more comment
  • Anonymous Apr 17, 2008
    If you have solved this error please inform mee, couse I have got the same problem.
  • amiram40 Apr 29, 2008
    I was looking at the web and it seems that this reset problem is very common.
    "Press the reset" problem
    "tape does not eject"
    they claim that the source of the problem is the main board.
    I am giving up and about to buy a new one, NOT Panasonic!!!
  • Anonymous Jan 18, 2009
    same here but no more garantiee!!!!
    can't even view the tape!! great service :(
SOURCE: Transfer of video from Panasonic NV-GS50 tape to computer
You will need a firewire card in your PC and firewire cable to connect your camera to the PC. you will also need a software like Windows movie maker which can help you to transfer videos from your camera to the PC.
Posted on May 19, 2007
SOURCE: trouble with finding Panasonic NV-GS11 Mini DV Digital Camcorder driver / software
NV-GS11
Posted on Dec 22, 2008
Sertion
SOURCE: driver softwar for NV-DS 65
You can download windows XP drivers here.
Posted on Jan 05, 2009
SOURCE: how do i reset my Panasonic nv-gs70
It is on the Right hand side of the camera, just underneath the finger grip. Next to the Auto|Manual Fucus button... about 2 cm to the right.
Hope that helps
Posted on Jan 20, 2009
SOURCE: Lost driver software for Panasonic NV-MX500 Camcorder.
OMG, took me forever to find the driver, contacted the support centre who told me I had to pay $25 just to get it on CD
Finally found it by doing a 'round-a-bout' search
http://www.panasonic.co.uk
navigate to support and downloads then type in "NVMX" and select 'software driver' scroll down the page till you come to NVMX50. Should be two downloads there, one the driver the other the audio update.
After installing this on my new dell pc, it was able to identify the camera and webcam... HOWEVER although I can get webcam to work via messenger, my mic is no longer working??? even after the audio update so go figure??? I use to be able to use the mic on skype before downloading this... what a pain
Posted on Mar 03, 2009
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
Mini DV tape won't play in panasonic nv-dx100 PAL
Have you found any solution to the F01 error? I just got the same issue. Thanks!
Feb 28, 2010 | Panasonic NV-DX100 Camcorder
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Panasonic Mini DV NV-GS11EG "push the reset button"
i know what to do next brother go to field or a soccer field and trow the bloddy thing away
Mar 25, 2008 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
Tape notification - Panasonic NV-GS11 Mini DV
Dear sir, Please check right side of the mechnism their will be plasic stud. Clean that stud properly. & check tape inserting side some metal type contacts also clean it will be in right side of the mechanism. thank u. reply if any problem
Jan 14, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic NV-GS11B Mini DV Digital Camcorder Logo
102 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
