Question about Kenmore 24032\24036 Top Load Washer
Speed Control only works in Heavy Duty
Hi There: My Kenmore washer (model 11020722990) with a 3 speed control only works in Heavy duty mode, the other 3 ways make a noise like a relay but doest work fine, the noise is constant until i chsnge it to heavy duty that works fine. thanks for your help
    Sergeant:
    Champion:
  • 291 Answers
Sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Posted on Nov 24, 2008
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Washer wont drain
when you lift the lid there should be a switch if you push it down with a pen or something it should drain If that does not work then it's the control knob but I'm betting it the the lid switch
Jan 07, 2012 | Kenmore Washing Machines
Washer does not work at regular speed, it works on other setting
Since the machine works in two of the three speeds the problem points to either the timer or the switch that sets the speed.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Go to the control panel category and see their diagram and list of switches and parts.
These aren't that difficult to replace but they aren't inexpensive.
Sep 14, 2009 | Kenmore 15864/15862 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
246 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
