Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Electic chord power supply is cut and chord isnt marked to determine corrct wring
    Champion:
  • 210 Answers
The plug has a large and a small prong, the large one is the neutral or ground. test the ends of the cut chord to the metal of ref. the one that has continuity is the neutral and the large prong plug.
Posted on Nov 26, 2008
How do you fit new grass cutting cord when the cord supplied runs out??
Take both ends and double the cord and roll on the spindle in the opposite direction so when you release the cord automatically by turning the release knob at the bottom ,it would release the cord.
Sep 22, 2014 | Garden
Where's the fuse on speaker
if your talking about a speaker that is powered by a speaker it dont have one but if you talking about a seperate powered speaker it will be located around where the power supply is where you see the power chord going into the speaker inside you should find it around there.Im guessing your speaker isnt powering on am i right if i am you are doing the right step in diagnosing your speaker this is the first thing i'd investigate.
Mar 14, 2013 | Klipsch Audio Players & Recorders
No power supply. and we cannot determined the model of the chips we are going to buy. all i need is the diagram of this model. he you can contact me anytime. thank you very much.
no power supply from where? you should have 40 amps of powere from your elect panel and you should only need to install a plug onto the range
Nov 19, 2010 | Kitchen Ranges
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
Power chord problem
(1) Does the machine work with the cord plugged, if so it is the battery or the charger circuit at fault
(2) If it does not work then there is either a break in the cable where it enters the plug which plugs into the back of the laptop or the power supply has failed
Aug 31, 2009 | Sony VAIO VGN-NR430E/S NoteBook
Power chord must must moved continually to show charge
Yes, this is common, if the power cord at the connector is flexed continually then the metal fibres in the cord will break due to metal fatigue.
You can cut off the connector away from the break and fit a new connector on the cord, make sure the the wires are soldered correctly to provide the correct polarity at the connector.
The problem could be at the laptop where the connector plugs into the laptop's power socket. It could have a dry solder joint or the socket is faulty. This requires dismantling to repair.
The HP warranty would cover the normal warranty period and would not extended for worn parts.
Apr 15, 2009 | HP Pavilion dv6000z Notebook
IN NEED OF A POWER CHORD
Does the unit need an adaptor or just an AC power cord? If it has an input jack similar to other DC input devices that use a 'wall wart' type with a large plug (actually a primitive power supply), you need to determine what voltage and current it needs.
Oct 05, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Power supply cable
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Jul 24, 2008 | Toshiba DP80F Printer
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Aug 16, 2007 | Toshiba 20HL85 20 in. LCD Television
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
