Question about Whirlpool LER4634J Electric Dryer
LER4634J got ''shocked'' and now won't operate
The dryer was running and I touched the back and got shocked the dryer shut off, the breaker wasn't tripped but I reset the breaker anyway and tried it again and it still won't operate. Is there a fuse or something?
    Problem Solver:
  • 10 Answers
First, test voltage to be sure your are getting 240v into the machine. Sometimes there are to 120v breakers in the breaker box that have to be reset. Check to be sure yours are fully reset.
Posted on Dec 19, 2008
LG DLEX2801L Electric Dryer. Won' t stop tumling even when turned off. Only when the door is opened will it stop. The check filter is lit up but I clean it after every use and I have made sure there are...
The breaker won't reset? Or the dryer? If it.s the breaker, it is protecting you from a short circuit and a possible electric shock. Are you sure you want to try to fix this without a professional?
Feb 06, 2018 | LG DLE2514 Electric Dryer
New Maytag Electric shock
I believe you dryer is not hooked up correctly electrically.
You will need to unplug it from the wall without touching it.
You may need to use a wooden broom handle or some other insulating items to accomplish this.
Remember, electricity cannot flow through dry rubber, paper, cardboard, or wood.
If you cannot move the dryer away from the plug so you can reach it, you will need to shut off the dryer at the breaker box or fuse box before you start to unhook it.
The breaker box or fuse box should be marked on the paper on the back of the door as to which 2 circuit breakers or fuses are for the dryer, but most are not.
You should get someone smart to fix this before you have a fire or someone killed .
Be blessed.
Jun 14, 2013 | Maytag Dryers
Whirlpool dryer won't dry clotes Model# LER4634PQ1
Dear Sir:
Please see this possibles causes:
Power from the house
test for blown fuse or c. breaker tripped, change or reset.
Heating element
test for burn or open heating element see the video
Thermal fuse
test for open fuse, see the video
Wiring
test for burn or break wires. test for continuity.
God bless you
May 23, 2012 | Whirlpool LER4634J Electric Dryer
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool cloths dryer mod# yler5848eq2. I recently spent alot of money buying 30 amp type D screw fuses, the fuse that keeps blowing is the motor fuse,everytime we start the dryer it will run...
All I can figure is that your timer points are shorted at that place in it. Reason being is, the cool down turns your element off. If it turned things on, what ever it turned on would be the problem but with it turning things off, it tells me it's a bad timer. Also it's blowing the breaker at the same place in the timer. Sorry but I diagnose it as being the timer and they are not cheap.
Just in case, try this. Check you element. Make sure it's not broken. I have seen them broken and they would work until they got hot. When they got hot enough they would warp and touch the housing, blowing the breaker. What ever it is, your looking for a dead short. That is all that would be blowing a new 30 amp breaker and nothing other than the dryer operating off of that circuit
Oct 12, 2009 | Whirlpool LER4634J Electric Dryer
Is there a reset button after heating up and
Not sure about your model.
Look on the motor, sometimes there is a reset button on the motor.
Sep 25, 2009 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer that has been blowing the breaker, and is not heating up to dry clothes
how long is it run when breaker is blown? element could be blown and shorting to the cabnet. motor could be full of lint
Jun 28, 2009 | Whirlpool LER4634J Electric Dryer
Will dryer work if timer is inoperative
Check the breaker first, then check the connections in the back of the dryer, then check the element itself. It may be burned in two. The timer may be coincidentally bad as well.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
Guru
Runs but no heat? check your house breaker or fuses it takes 2 thirty amp breakers or fuses if you have breakers flip them off then back on several times. then try again still no heat you would need a volt- ohm meter to check the element, t-stats,thermal overloads etc. If you have fuses just replace them with 30 amp time delay fuses and try again.
Oct 18, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
