Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
No spark
By lester_fende on Nov 23, 2008
we had a gas leakand it ran down to the coil and flywheel. The engine quit and wouldn 't restart. no spark. I replaced the coil and still no spark. the insulation on the magnet appears to be good .I need help please.
Best Solution
posted on Dec 01, 2008
Very Helpful)
PC_Tech50
Rank: Guru
Rating: 96%, 277 votes
Here are a few pointers from a former pressure pump tech. Usually no spark is caused by the low oil safety system or spark plug wire shorted. This system will prevent the engine from starting if the oil is dirty or contaminated with gas. Try disconnecting the oil sensor and the kill wire from the coil. If no joy re-install the old coil and test without oil sensor connected. The spark coil can be tested with a growler used to test armatures. Sometimes a shorting sparkplug wire can be found by pulling the starter rope in a dark room and look for sparks jumping to metal. enjoy
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
i have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i... (More)
Answer
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal... (More)
Answer
My pressure washer was running fine then bogged out.The person who lent it to me said dont worry... (More)
Answer
FHH25A pressure washer I am looking for the exit tube that comes off the pump, the hose of the wand... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure Washer Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
