Question about Dell OptiPlex 170L PC Desktop
Dell Optiplex 170L does not recognise an 80GB Hard Drive
I've tried to upgrade a 40GB drive to an 80GB drive on my Dell Optiplex 170L. I used Ghost to copy the C: & D: Partitions over to the larger drive and I'm now getting a message at boot up of "A disk read error occurred Press Ctrl+Alt+Del to restart".
If I press"F2" during the bootup and look at the "Drive Configuration" the BIOS seems to recognise the "Primary Master Drive" and automatically show it as 80020MB (in an Aqua Marine colour).
I've check the BIOS version and it is A07.
If I press "F12" (for Boot Menu) during bootup and select "7. IDE Drive Diagnostics" it shows the Primary IDE as Drive 0 : ST3802110A (i.e. my seagate 80GB drive)
I'm a bit stuck now, can you help?
  • 6 more comments
  • simon_king_6 Nov 23, 2008
    No Diskette in the A: Drive and no CD or DVD in the DVD writer. The Boot order is A: then E: (DVD Drive) then the Primary IDE Drive
    Ghost was used on a totally different unit (which reliably ghosts disks) using a ghost boot disk, 40GB disk then 80GB disk (in a caddy). a Ghost Multicast server was used to make an image of the 40GB drive and then apply it to the 80GB drive (re-sizing the partitions as a result)
    Nothing else was added (i.e. no SATA controller etc.)
    Already changed the boot order so that the Primary IDE (80GB drive) was the first one in the list and to make sure I disabled the A: Floppy Disk and the E: DVD-Writer. I'm not doing much giggling. Thanks for your help though.
    I have done the same to a second PC (my Sons) using ghost (again) so I don't think re-ghosting will help. It's got to be something like a BIOS limitation or a hidden partition that Dell needs and it wasn't ghosted across for reasons unknown.
  • simon_king_6 Nov 24, 2008
    I still have the issue
  • Anonymous Jan 11, 2009
    I have the samme problem with a 270. it came with a 40GB seagate. I tried to replace with 250gb WD. Used copy Commander to clone and expand the disk. exact same error message, exact symptoms. Flashed the Dell BIOS to latest. no help. repartitioned the drive to 40gb and 210 gb. No help. Changed cable select jumper from Cs to master, no help. Copied three times, no help. i suspect it has something to do with either the system is expecting a seagate 40 gb drive due to some setting somewhere, OR I wonder if it has something to do with the business nature of the machie (I bought it off lease from tigerdirect0 perhaps an "asset management" setting? Still stymied
I have the same problem. With SATA it boots perfectly, but on a IDE it fails.
Posted on Jun 17, 2009
  • 837 Answers
Just for giggles try changing the boot order so that the C drive is first
Posted on Nov 23, 2008
  • 837 Answers
Is there a disk in the A drive?
  • 1 more comment
  • Jay Glendenning
    Jay Glendenning Nov 23, 2008
    Was the Ghost program on the A drive?
  • Jay Glendenning
    Did you add a SATA controller at some time?
  • Jay Glendenning
    As much as a pain as it is .. try re-ghosting
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
No boot device available dell optiplex 170l series
Go to the bios to verify that the computer is recognizing the hard drive and that the hard drive is is listed in the boot sequence. If this is all good your hard drive may have been formatted or erased or the boot record is corrupt and unreadable to the bios. I had a similar problem. reloaded windows and all was good.
Feb 12, 2013 | Dell OptiPlex 170L PC Desktop
Failing to install xp on dell optiplex 170l. setup cannot find any hard disk drives
try to use windows 7 or vista maybe the RAID of your hard drive wont detect windows xp version.
Sep 12, 2011 | Computers & Internet
I want to upgrade a 80gb to 500gb for a dell inspiron 9400.I used norton ghost to clon it and it reduced the size of the new Hd to 80gb as the original. I tried acronis with the same result.How can I solve...
I"ll give you a fast response one way. Most extreme also is to put your os disk back in the drive which will completely empty the drive. Make sure you have drivers in a convienent location.
You can't reduce a hard drive so I suspect the norton ghost clone is 80 gb on one area of the hard drive while the other 420 is unused. Press the function keys to go into the bios or check the computer: click start /computer /right click drive and properties to see how hard drive is being used.
Dec 13, 2009 | Computers & Internet
Im trying to upgrade my hard drive from a 40g to a 160 but it only shows up as 40gb
You probably used software to "clone" the "old" disk-drive to the "new" disk-drive. So, the "new" drive is an *EXACT* image of the 40GB drive.
Click Start
Point to My Computer
Click with the SECOND (usually the RIGHT) mouse-button.
Click Manage
Double-click Storage
Double-click Disk Management (local)
You'll see that the "last" 120GB on the new disk are "unallocated".
Use that "disk-cloning" software to "resize" the 40GB partition on the new disk-drive, to integrate that "unallocated" space into the current partition.
Or, right-mouse click on that "unallocated" space, and create a partition within that space, and to "format" that space, and to assign a drive-letter (E: ? F: ?) to that 120GB of disk-space.
Nov 11, 2009 | Dell Dimension 3000® Pentium® 4...
Dell optiplex gx110 733mhz won't recognise another hard drive
this time external hard disk drive to you Dell... this Dell optimized for only that 10GB drive..
Jun 17, 2009 | Computers & Internet
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Oct 08, 2008 | Dell OptiPlex 170L PC Desktop
IDE MASTER DRIVE ERROR
Sure sound like you hard drive is starting to have a problem. I would clean and defrag it after backing it up. start- my computer- right click on hard drive-properties-disk cleanup/  After that then 'tools defrag hard drive. then run scan disk
Jul 14, 2008 | Dell OptiPlex 170L PC Desktop
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
Feb 20, 2008 | Dell OPTIPLEX GX1 PIII-550MHz 128MB 10GB...
Dell OptiPlex 170L PC Desktop Logo
2,023 people viewed this question
Alun Cox
