Question about GE JRP15 Electric Single Oven
Oven will not heat up!
Just put in a ge jrp15 single oven, the unit has power and verything else seems too work, but won't heat up? Unit is clicking, butwhich I take as the unit trying but won't move up in temp? maybe a faulty temp probe or element I just dont know, HELP ME!!
  • myersd Dec 05, 2008
    I have the same problem! My heating element glows red, but its not heating above 125 degrees
  • boarderchick May 11, 2010
    how do i test for a faulty element
  • GE Master
  • 3,463 Answers
Hi.
Probably faulty element, but you would need to test it to be sure.
Posted on Nov 23, 2008
Oven cannot maintain chosen temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 10, 2010 | GE JRP15 Electric Single Oven
Flashing F1 and beeping, on a GE JRP15 Electric Single Oven. What does it mean?
This is usually a control board failure, but sometimes can be caused by the keypad. There is a procedure outlined in the tech sheet to determine which it is.
best regards,
Bruce
www.fixyourboard.com
Jun 15, 2010 | GE JRP15 Electric Single Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
JRP 15 oven showed 350F and gave preheat beeps. Frozen lasagna "cooked" 45 mins and was still almost frozen. Oven was warm inside, not hot. Bottom element glowed orange when I increased the temp setting...
The oven was obviously not heated to 350 even though this was the setting. There is a very simple proceedure to calibrate the oven. It is different on different makes of ovens. Your owners manual will give you the detail of how to reset yours. If the manual is not available, click on the following link. Hope this is helpful.
http://www.applianceaid.com/temp-change.html
Oct 05, 2009 | GE JRP15 Electric Single Oven
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
May 26, 2009 | GE JRP15 Electric Single Oven
Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
was the thermistor that connects to the heat board replaced?this is the bulb inside the oven that monitors the heat,it should have 2 wires going to the board.try wiggling these wires and see if it starts to heat,if so the thermistor is bad.
Jan 06, 2008 | GE Monogram® ZET3038 Dual Single Oven
F8 malfxn code
replace control board.
Dec 05, 2007 | GE JRP15 Electric Single Oven
GE JRP15 Electric Single Oven Logo
89 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
