Question about Philips DSR708 DirecTV DTV Receiver / 70-Hours Video Recorder
DirecTV DVR Shuts Down and Re-boots Without Warning
I have two DirecTV DVRs, both Phillips DSR 708 DVRs. Have had problems with both shutting down without warning, and then automatically re-powering up going thru the entire DirecTV power-up sequence. Have tried unplugging and leaving unplugged overnight. This helps, but after a while, the problem recurs. Called DirecTV, but they were no help. Would appreciate any suggestions or information that would identify the cause of this problem and how to solve it. Thanks
  • Connieh414 Feb 03, 2008
    I am having the same issue with my dvr. It will go for a couple days and then start the pattern of rebooting everyday for the next 3 to 4 days. Any solutions... It is very annoying!
    Sergeant:
  • 308 Answers
With the DVR up and operating well I would lift up one corner about 1/2 inch and drop it to see if that causes it to malfunction. If it does, then you likely have one or more bad solder connections inside that need repair. If no change is noted, then it could possibly be defective capacitors or a voltage regulator going bad on you. There is also a possibility that it could be a worn recepticle the unit is plugged into, as a power interruption may be all it needs to reboot.
Posted on Dec 29, 2006
SOURCE:
My TV Modele ALT2220 and brought from Singapore on 15th.Dec.2010 Mohemed musthapa
sir i have dvr ksr 708 los tha admin password plz you send master resed admin password
Dec 24, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
Phillips dvr won't power up. Lost power at house
Try hooking it up to another (working) electrical outlet. If that doesn't work, there's several possible problems.
The most likely is that the box was fried when a larger-than-usual current traveled down the line (or even down the coax if lightning struck and your system isn't adequately grounded); the electrical outlet is either pushing too much or too little power; or your house's ground polarity is reversed.
More than likely your box is bad. If you don't know very much about electrical systems, don't go messing with your ground or any outlets without a wall plate.
Dec 26, 2009 | Philips DIRECTV R15
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Mar 17, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Phillips DSR Receiver to 2nd or remote TV
If you are asking if you can use yellow-red-white to one tv and rf coaxial to another tv at the same time to watch the same show, the answer is yes.
Jul 17, 2008 | Philips DSR708 DirecTV DTV Receiver /...
RCA DVR40
My RCA dvr 40 did the same.I think it was overheating.I vacumed the fan opening and put small blocks of wood under the legs and that worked for about 3 mos. then it said powering up but wouldnt. i'm now replaceing the unit. Good luck
Apr 09, 2008 | RCA DVR40 DIRECTV DVR with TiVo
Phillips DSR 704 Problem
It could be the hard drive, it could be the unit. The first, and easiest step is to replace the drive.
Dec 01, 2007 | Philips DSR704
How to read dvr messages
From the R10 user's manual:
From time to time DIRECTV may send you messages about updates to your service and other important notices. These messages are important, useful, and easy to find. When your DIRECTV® DVR receives a new message, a message icon ( ) appears on the channel banner and in DIRECTV Central.
To read a message:
1. From DIRECTV Central, select Messages & Setup.
2. Select Messages.
3. Select the message you want to read.
Use the CHAN DOWN button to see text that does not fit on the screen. When you are finished reading a message, select Done or Delete Message. Selecting the message icon in the channel banner will take you to your list of messages. The message list will display “No Messages” if there are no messages to read.
You can download the full user manual for your R10 here.
Oct 19, 2007 | Directv R10 TV Receivers and DVRs
Philips DSR708 DirecTV DTV Receiver / 70-Hours Video Recorder Logo
874 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
