Question about Toshiba Tecra 8000 Notebook
No connectivty to internet
My laptop has limited or no connectivity to wireless internet. I've done power cycles, restarted everything, reset my setting to a few days ago when it did work. My roommates' computers work fine and connect to our wireless. I called the cable company and he took me through a bunch of steps and said the issue wasn't with our internet connection or our router. I took my computer to starbucks to see if it would work there: just the same thing, high signal strength, tries to acquire network address, and then comes up as limited or no connectivity. My computer worked fine 24 hours ago, and I haven't done anything to it, so I don't know what's wrong. Please help.
  • 59 Answers
Hi buddy u will find the complete solution here
http://fixmypcandmac.com/forum/viewtopic.php?f=29&t=18
Posted on Jul 15, 2009
  • 33 Answers
Your problem is very indicative of an assigned ip address to your wireless card. Assuming you have windows xp as your operating system. Go to start, run, type in CMD, once the dos screen appears type ipconfig and look to see what your assigned ip address is.
Posted on May 20, 2009
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Router dropped connection and is now no longer discoverable. Wireless light is not on, power and internet lights flash. On reset power light flashes red but does not reboot. It is connected to pc using lan...
You just have to restart the router it self. i mean take out the power adapter and plug it back. No need to press the reset button as it may put back the router to factory default.
These kind of issues are common. The DHCP service (which gives IP to your computer and wireless device) hangs up some times on most routers.
Let me know if you still face the problem after power cycling the router.
Mar 18, 2011 | Computers & Internet
My desk top computer in the house is on-line, the laptop is not. Message says it cannot find any wireless networks - I tried everything listed except turning the broadband connection off - as that must...
Well, actually... it might help to turn the router off and then on again. Sometimes power-cycling the router can reset it, which might need to be done. I'm a big fan of the power-cycle; it works for all sorts of obscure problems.
Once the router is on again, use the laptop and adapter to check for wireless networks. If you still can't find a network, disconnect the ethernet cable from the back of the desktop computer, and try the wireless adapter with the desktop PC. If it works, the problem is with the laptop (possibly a power supply problem). If it doesn't work, the problem is either the adapter or the router.
Ideally you should then try your adapter with a friend's router. Eventually you will discover whether the router is playing up or whether the adapter is faulty.
In my (admittedly still limited) experience, connection problems are rarely about faulty equipment and more usually about incorrect settings, so it might also be worth running the New Connection Wizard from Network Connections in the Control Panel.
Oct 10, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Getting kicked off internet (wireless)
It seems to be that either wireless connectivty is breaking up or Wireless modem is Power off and on again and again. So, please check power connectivity first. if everything is right, simply call ISP. They will fix it at their end.
Mar 03, 2010 | Belkin (F5D7231-4) Wireless Router
Limited or no connect
Hi i'm Rain.
Limited or no connectivty means that your router is not picking up the connection or it is connecting but may have something blocking the connection.
To repair this you will need to reinstall the routers drivers to your computer. You should have a disk that came with the router. Use the disk to reinstall the needed drivers to connect to the internet.
If you do not have the disk , the easiest way is to call whom ever you got the router from and have them bring the disk out or go pick the disk up. Always remember when you have a router installed by a company the disk belongs to you. Most times the technician will not give you the disk because that way you will have to call them to come out to reinstall it. Thats more money outta your pocket.
Nov 29, 2009 | Linksys WRT160N Wireless Router
I hit the reset button on the router and now I can't connect to my wireless network. How do I fix this?
Try turning everything off- pc, modem, router, other pcs and periferals on the network, wait 10 minutes, then start turning everything on gradually- pc, modem router, etc. Hopefully everything will reset ok.
Jul 30, 2009 | Linksys Wireless-G Broadband Router
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
Toshiba Tecra 8000 Notebook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
