Rca 61in. tv is showing a curved picture. when the cable is off it shows a red, green, and blue curved line across the screen.
  • 2 more comments
  • quishab Nov 23, 2008
    it must was a problem on your end because i could see what you were typing. i dont know what a convergence setting is. all i know is that when i left home it was fine, i left it on while i went the store and when i returned it was like that.
  • quishab Nov 24, 2008
    yes it does, what should i do.
    it is a rca hd61w66
    this will fix my convergence board or do i need to replace the whole thing, which cost $92.
  • 4,889 Answers
Hello! This is eagle.. What happened.. You didn't type a single word! You tried twice and I picked up the chat both the times..Looks like some kind of connection problem.. I have been waiting forever for you to type! Anyways can you please post an image of the set powered on? Also did you try adjusting the convergence settings of the set?
Posted on Nov 23, 2008
  • 3 more comments
  • eagle338
    eagle338 Nov 23, 2008
    My end! Thats wierd! My message wont possibly get through may be something on the server side.. Anyways does the picture on your tv look like this?
    http://www.fixya.com/support/t326647-rea...
  • eagle338
    eagle338 Nov 24, 2008
    Saw you post another live chat request. Did you get what you wanted to know? If not post back. Livechat or not I will see you through this.
  • eagle338
    This means that the convergence ICs(STK) are damaged. Replacing them and some resistors around them would resolve this problem. However this is a pretty tough repair and not advisable if you dont have good knowledge of electronic repairs. The ICs cost around 60$(for two). Please mention the model number of your set so that I can get you the part number of the STK ICs.
    Regards,
    Sai.
  • eagle338
    The part number is STK392-040. Sanyo ICs are usually the best and my preffered choice. If you want to try doing it yourself then you will need to get a heat sink compound as well. Costs 11$ each. You will need to get two of them. Here's the link
    http://www.electronix.com/catalog/advanc...
  • eagle338
    The ICs will do for the fix. However you may also have to replace some resistors that may have gone faulty. Usually the parts including resistors for fixing this problem cost me around 35$-40$. So I dont think you need to get a new board.
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Screen has 3 lines at the top
you need to get a conversion done to correct this problem
Oct 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence Problem RCA HD52W59
you need to test all cables then make shure it is not your tv.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
