Question about Linksys EtherFast Cable/DSL Router
My LED on the BEFSR41 is blinking, and I can't get past pinging
Once I got the firmare file and the tftp file and unzipped everything needed to be unzipped, i changed the connection to 10MB duplex. Then I tried doing the run>command [enter]>ping 192.168.1.1 and it just says destination host unreachable. I hope you can help. I'm on the last step, I also didn't understand the setting up the Static I.p., what is the referance to answer ID, 534. please help :)
  • jvary Jan 20, 2009
    Great reply, and much more useful than that on the linksys page. I tried the above, but afterward when I ping to 192.168.1.1, it just times out. I can ping 192.168.1.2, but that's not as helpful.
    Maybe it's not the firmware, but my router is toast?
  • nicewood Mar 17, 2009
    Sorry about not being able to feedback, but YOU ARE AMAZING!!! I can now play my ps3 on NAT 2 and play my steam games with no lag or problems...also if you could help me on my new problem, it's on my page, with microphone static, but thank you so much! FIXYA!
    Scholar:
  • 132 Answers
  1. First you need to do a hard reset on your router. While the router is on, press and hold the reset on the router for about 20 seconds. Then, disconnect power from the router but keep holding the reset. Wait for about 15 seconds and then power on the router. Wait for another 15 seconds and then release the reset. You may need to stick a pen or a paper clip to push the reset button.
  2. Turn off the router for about 30 seconds and then turn it on agan. Check if your power light is still blinking.
  3. To assign a static IP address to your computer(in winXP); open Control Panel and click Network Connections then look for Local Area Connection.
  4. Right click on Local Area connection and then click properties. Then you will find a list of items used by that connection. Select Internet Protocol/TCP/IP then click Properties.
  5. Set IP address to Use the Following IP Address.
  6. The IP address you will configure to it is 192.168.1.2. The Subnet mask is 255.255.255.0. The Default Gateway is 192.168.1.1. Just leave the DNS server addresses blank.
  7. Click okay all the way out. Then try to ping 192.168.1.1.
  8. If you're able to get reply, then you may proceed in upgrading the router's firmware.
  9. Make sure also that firewall is off in your computer.
Hope this helps!
Posted on Nov 23, 2008
Unable to connect to the router! check that the router has been connected to the pc. i have already reset my router. the lights are flickering constantly. pls help me
sounds like your router is bricked.
you can try unbrick it by downloading the latest firmware from linksys.com
if your running win xp you can tftp the firmware to your router.
first you need to set your computer to a static ip address
192.168.1.5 subnet mask 255.255.255.0
then go to start run.
type cmd and hit enter
a black window should appear
you should be able to ping the router. type
ping 192.168.1.1
if it returns successful then do the following. if it doesn't change your network settings and make sure u got a static ip.
unzip the firmware you downloaded to drive c
type
tftp -i 192.168.1.1 put C:\nameoflinksysfirmware.bin
hit enter
it should say successfully uploaded if it works. go ahead and power off the router and power it back on.
if that doesn't work try uploading it again.
Apr 12, 2011 | Linksys Wireless-G WRT54G Router
After firmware upgrade my dsr 2035 switch is not coming up the power led is blinking in grenn it is blinking
you stuck in Upgrade mode, a TFTP recovery is needed. There are instructions on the Avocent Website (check the release notes) on how to do this.
You might want to download Solar Winds (TFTP Freeware program) to get this done in 5 minutes.
Jan 18, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
Can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Hello, I saw the article on the fix on the BEFSR41 and the blinking LED, and I was able to find the firmware and put it on 10MB speed, but when I ping the 198.168.1.1 it says destination host unreachable,...
if you have lowered the card speed and cannot ping the 192.168.1.1, have you set a static IP address on the computer, if so what was it? because if you have set a static IP of 192.168.1.xx and still cannot ping the router, this means that your router is already defective. you may want to contact linksys for replacement
Nov 23, 2008 | Linksys EtherFast Cable/DSL Router
Power light flashing/blinking on the BEFSR41 V3
This is caused by the firmware not loading correctly. Follow the steps below to fix this. 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your Router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have. Be sure to select the correct router version (BEFSR41 V3), as firmware upgrades vary by version. 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring up the MS-DOS prompt window. 3. Type ping 192.168.1.1 and press [Enter ]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL= 128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's Power light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Red Diag light blinking on the BEFSR41
This is caused by the firmware not loading correctly. Follow the steps below to fix this: 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version (select BEFSR41, do not select BEFSR41 Ver. 3 ). 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. 5. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring upthe MS-DOS promptwindow. 3. Type ping 192.168.1.1 and press [ Enter]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's red Diag light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Linksys EtherFast Cable/DSL Router Logo
2,078 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
