Question about Panasonic SC-AK44 CD Shelf System
CD Player My CD player on my Panasonic SC-AK44 stopped working. As the HiFi is out of warranty, and it's usually cheaper to buy a new one, I thought I'd have a look inside myself. The first problem that occurred was I would put a CD in tray 1, then change to tray 2 to insert another CD, and the one I put in Tray 1 popped out. The same thing happened when I opened the other 3 trays as well. Then I managed to get a CD stuck inside. When I tried to open the tray, it wouldn't come out, and was making a sound as if it was caught on something, or something was in the way. I have the system opened, got the CD out, and tried to re-assemble the CD player, but I have a couple of items that i'm not sure where they go, so I am looking for maybe a diagram that would show me how it should look, so I can make sure I have put everything back where it should be. Any/all help appreciated!!!
techman
  • 3130 Answers
SOURCE: u99 code and tray won't open
Thats a reset code # its on page67 of your owners manual. Unplug the unit for a bit(5minutes) plug in turn on the power then turn off again then back on. If this dosent clear the code, contact panasonic at 800-211-PANA Good luck
Posted on May 10, 2006
furion187
  • 54 Answers
SOURCE: dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
  • 905 Answers
SOURCE: DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
Posted on Oct 18, 2008
  • 62 Answers
SOURCE: cd tray won't open
get it serviced as it happens due to the old band or ring kinda thing in the tray which aids in opening of it.
Posted on Aug 28, 2009
My Panasonic SC-AK44 won't read my disc in my 5 disc player. I have cleaned the laser carefully it played the discs, I went to put the discs on Radom, now the disc player won't read my discs again.
You will have to clean it again. But when you do so also check the rest of the mechanism for dust. You can get a special spray can of dust blaster (from Amazon) that will help remove the stuff!
Presumably when the mechanism switches the discs, it dislodges dust particles!
Sep 21, 2015 | Panasonic Televison & Video
Remote control volume doesnt work
May be some sort of leakage. Remove the back cover and see
Apr 08, 2014 | Panasonic SC-AK44 CD Shelf System
I have a panasonic stero 5 cd system. model sc-ak44 after moving and plugging it in, the cd player just does not play. the flashing light says no cd when in fact there is a cd in there. it is put in the...
It's possible the laser assembly got damaged or dirty.. Inside the back cover of your users manual is a procedure to protect against that. Trying to clean the laser yourself would possibly lead to more damage as they are protected from view even when the units outer cover are off. I no longer actively repair electronics, but I can tell you a repair costs more after a customer attempt at correction than the original failure. Lasers are finely positioned mechanisms. I would suggest professional service.
Nov 25, 2017 | Panasonic SC-AK44 CD Shelf System
Panasonic SC-AK600 CD player says "no disc" when
Your cd laser lens has got weak.get it replaced.
you can replace only the lens or the whole laser pickup.
Dec 29, 2010 | Panasonic SC-AK600 CD Shelf System
Cd player stop playing... Message....no disc,...no data or it simply keeps searching for the tracks on the cd. How can this be fixed?
Try cleaning the lens with a CD lens disk cleaner, see if that rectifies the problem. Hifi systems are notorious for dust buildup being an enclosed system with an exposed cd drive deck.
May 24, 2010 | Panasonic SC-AK100 CD Shelf System
Dear Sir/Madam I have this Panasonic Hifi sys...
May 20, 2010 | Panasonic SC-AK27 Shelf System
Hi my technics hifi is playing up, it turns on but the stereo sound processor will not come on.this needs to work for the hifi to work can you help
hi mate, the sound processer has packed up, mines done exactly the same thing, i've taken it in to a panasonic technics specialist and the verdict is just that. i've confirmed it by swapping the sound processor with one off a friends stereo and mine came back to life. Hope that helps mate.
Feb 21, 2010 | Technics SC-DV290 System
Remote control for C D stereo system SC-AK44
according to www.rca.com they have the remotes for this stereo for sell just go to this website go to technical help and they will get you one i just bought a new one myself
Apr 03, 2008 | RCA 100-Watt Stereo System With 5-CD...
Panasonic SC-AK44 CD Shelf System Logo
53 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
