Kenmore 70 series
It makes a whinning noise and kind a belt was broke and i do not know what to do when i shut the lid water goes in it seems like everything works but spin cycle can you help?
  • 116 Answers
REPL/ PUMP
Posted on Nov 30, 2008
Kenmore 70 series washer will not drain? It makes an electric click noise which makes me think the lid switch is ok, but i don't know. Won't drain or spin.
There is a good chance the lid switch is bad. The model number is usually under the lid hen you open the lid check at the back of the opening when the water injector is.
May 17, 2014 | Kenmore 24932 Top Load Washer
WAsher BROKE!
lift the lid up and down,if you don't hear any clicking the lid switch broke,if that's not it check the motor coupling,take the two clips off that hold the pump in place,remove the two screws and the two clips that hold the motor in place and the coupling is on the back of the motor,if the washer is dead it's the lid switch,if it makes a grinding noise but doesn't move then it could be the coupling,let me know how you make out
Jul 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series. It won't agitate, drain, or
Does it make motor noise?
Check for belt issue if there is a motor noise and no spin.
Feb 14, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washer water not draining
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely (frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case, check the pump's pulley before you replacing the belt. Let me know if you need for further assistance. Good luck
Sep 10, 2007 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
