Question about Microsoft Xbox 360 Console
No color on xbox
My xbox360 screen on games and the dashboard is in black and white its video is set on 480p i dont know whats wrong it only went in color on 1 of the TVs in my home.
I am having EXCATLY the same propblem except its color on my pc but on everyother tv ive tried its black and white except one but i dont know why
Posted on Dec 30, 2006
    President:
  • 2,961 Answers
I don't know the A/V leads you get in the US but in the UK you get red/yellow/blue/green and white. If you are using these make you use the all red and all yellow and blue if it's audio left/audio right and video. If your'e using composite,you use all leads apart from the yellow video as you do not need this when using all other plugs. ensure the hertz rate of 50 or 60 is set correctly also.
I have one of the brand new xbox 360s i have a problem.. on some xbox360 games it dont play on pal 50 only pal 60 but its black and white
Does the new Xbox 360s have a HD / TV switch on the av plug like the old model did? If so you might have it in wrong position. I think you can only alter the Pal settings when this switch is set to TV. If old tv it may not work in Pal 50 at all only Pal 60.
Jan 01, 2011 | Video Game Consoles & Games
My xbox 360 has lines and wrong colors on screen right on startup but never frezzes
This is a GPU problem more than likely the graphic processor is wearing out . If this is not fixed it can cause E74 Error and you have to buy a new 360 or get it repaired . For repairs visit TheXboxExpert.dotcom . This is my good friend and he can fix E74 so that you dont have to shell out $300-$400 for a new xbox360 . If you start seeing black spots during a game SHUT OFF THE xbox360 if left on may cause further damage .
Jul 13, 2010 | Microsoft Xbox 360 Console
PAL 60 Display Problem
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/917304
Please let me know if you have any issues.
Regards,
Feb 12, 2010 | Microsoft Xbox 360 Console
When I turn on xbox 360 it blures with lines down the screen
Your AV cable might be bad or you have an Hd Tv & dont have your Video setting set up right on your Xbox 360 go to http://www.xbox.com/en-AU/support/xbox360/digitalmedia/viewvideo.htm
Sep 05, 2009 | Microsoft Xbox 360 Console
No Color
check the color and display settings on the 360 as well as the tv
Oct 24, 2008 | Microsoft Xbox 360 Console
Xbox360
well it seems that your xbox is well and truely broken. contact microsoft and tell them whats happened and if you have done nothing wrong to cause your 360 to break then they will repair/ replace your xbox for free
Jan 05, 2008 | Microsoft Xbox 360 Console
360 video problem on HDTV
I need a little bit more info on the TV its an RCA what?,
In the mean time what you could try is finding someone with a HD tv and trying it out at there house so that you can single out if it is your system or the TV. This will help alot you can also try someone else's xbox 360 at your house on your tv to see if it is your AV cable / xbox360.
Dec 31, 2007 | Microsoft Xbox 360 Console
Xbox 360 - While setting up in menu the TV went black and msg. No Sync. Signal
First, make sure you select either TV or HDTV selector on the Audio Video Cable that came with the XBOX. Second, if you chose TV plug the Audio/Video Cable connectot that are red, white , and yellow in color to your TV. Now see if you can see the Start up on the XBOX360.
If you still dont get anything, try plugging it on another television and see if that fixes your problem.
Dec 09, 2007 | Microsoft Xbox 360 Console
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
382 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
