Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
More on flyback replacement
I just inherited a D52W20 with the same problem described by a user back in April - the Antenna/Cable jack was broken off the back and the TV powers on for a few seconds a time, but no picture. You mentioned replacing the flyback which was inexpensive and offered further assistance. Can you give me any insight as to what to order and how to install it (in particular how to get the back cover off)?
Thanks,
Kevin
  • RCA Master
  • 8,617 Answers
Kevin,
You can get a replacement flyback #259296 at the following link and they provide free installation instructions with detailed pictures on how to do the repair. I would also let them know about the antenna/cable as they have all parts available for your model and they have a reputation of making good deals on parts that they have a large supply of. You can leave them a email include the model number of your set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Nov 24, 2008
Where does my coax cable plug into this tv? I can't find the cable jack.
In between your composite inputs and audio inputs on the back, there should be a coax plug that says antenna/cable. Plug it in there and you should be good.
May 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
COAX ANTENNA/CABLE INPUT BROKEN
Hey, Im pretty sure the it can be soldered back in or replaced with another.
or if the damage is extensive then the whole board might need to be replaced hard to say from here.
Id need to find the service manual to get the part numbers. Il look but i think they cost.
Apr 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
So...I'm told that I have a bad ballast in my 52" RCA projection TV. Can someone describe to me what the ballast looks like so I can I.D. it whan I open this TV up again for the 3rd time.
If your model is the D52W20 RCA you dont have a ballast you have a flyback transformer. Locayted on the far left side looking in the rear. Its a 259296 flyback and you can get one at www.tvrepairworld.com the flyback comes with the CD with detailed instructions
Nov 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have inherited RCA television with AV input on back, but remote and using buttons on TV allow only channels 4 and 7 to be be seen. How do you make televsion recognize AV input from back? RCA model F20600...
Bring up your video menu, make sure the cable/antenna mode is set correctly. Also do channel search/ auto program. If your AV is operating a DVD player etc., there should be a button to switch from TV to AV. If you are trying to input Cable/Antenna to AV jack you may have it plugged into wrong jack, it should go into 'antenna/cable in' jack. Hope this helps.
Nov 08, 2009 | Televison & Video
Tv shuts off
Resolder FBT flyback transfomer/on deflection board and bottom pinns on turnerson the ssb board.
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
2000 flhtcui broken tour pak radio antenna stud replacement
the stud is held in place by the cable jack. unscrew the jack from the back of the assy inside the pack under the liner. The stud should just slip out. You do not have to remove the entire light assy to do this. Just the part the cable screws onto.
Sep 20, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52w20 No picture
I dont believe that you need a new CRT. It sounds like you have a solder issue around the flyback, thats a common problem with the ITC222 chassis when the symptoms your describing are present. I would try resoldering the flyback and surrounding components and see if that doesnt correct your problem.
Aug 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Digitial TV Converter
The antenna connects to the ant jack on the digital converter box. The cable you are describing goes from the tv jack on the box to the ant jack on the tv. If this does not work we will need more info. Hope this helps.
May 13, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
