Question about Garden
Sputters & quits at proper RPM for engaging trans or mowing deck
Mower sat for 5+ years - cleaned carb, replaced all fuel lines, fuel pump (diaphram toast), plug, fuel filter, air filter. Motor starts fine and runs beautiful at low RPM but sputters and dies at RPM needed to mow. Breather tube is cleaned and open. Throttle linkage appears OK and choke is working OK. When I hold the choke in the perfect ''position'', I am able to throttle it up all the way with no problem. The minute I let go of the choke it returns to its preset fully open position and dies. Could this be a governor problem? Thanks for the help...
    Sergeant:
  • Garden Expert
  • 417 Answers
The jets may need to be turned a half turn in either direction while running, and then adjusted if they are gummy inside.
Posted on Nov 21, 2013
  • 51 Answers
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Posted on Nov 24, 2008
My husqvarna yth2348 riding mower is havering carb issues not getting fuel
If this is a briggs and stratton they have a fuel pump on the front of the carb and ethanol plays havoc with the diaphrams in the fuel pump. I have to overhaul the fuel pump each year. Before you try anything else try "mechanic in a bottle" first. It is available at home depot, lowes, tractor supply etc. Just follow directions on the bottle and often it will clean out the varnish deposits in the pump and the carb both. Hope that helps.
Apr 15, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower will not go forward .... it runs .... and the deck still engages but will not move forward or backward
i would inspect the belt the mower and the trans operate from different belts
Jul 10, 2012 | Garden
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The 12.5 murray 38 in runs fine until i engage the blades,while engaged the mower runs fine for about five seconds then starts to spit and sputter.once i disengage the blades it runs smoothly again
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Jul 07, 2011 | Garden
Engine starts and runs fine, then dies.
My 5hp B-S is doing the same thing and found a post that seems to be the best answer. Replace the float. It runs out of gas if the float is not working properly.
Another cause may be the diaphram, maybe.
Mine is 12 yrs old so I plan on getting the whole carb rebuild kit
while I have it apart
Good Luck
May 16, 2010 | Mtd 22" Yard Machine Push Mower
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Engine stops after ~ 15 - 20 min of mowing
try changing the spark plugs. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Nov 05, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
534 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
