Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Dirty flames My Danby propane kitchen stove's burners are emitting dirty flames and blackening the bottom of the pots etc
  • Selector Twentyfirst Apr 30, 2013
    which sovents can i use to clean it
  • 833 Answers
You have a problem with either air supply or with the burner getting dirty.  Clean out throughly with solvent type cleaners...no abrasives.  You should only have blue flames.
Posted on Nov 26, 2008
Our gas stove emits black smoke which makes our pot dirty
Write your answer...cleanining burner really helps,i have been facing that same and i cleaned my stove,it helped.
Oct 06, 2012 | Kitchen Ranges
Carbon residue on pots
There is an adjustment for correcting the air mixture on the gas line going from the knob to the burner. It usually is located at the point where the adapter nozzle enters the gas line going to the burner.
Aug 13, 2017 | Kitchen Ranges
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Mar 26, 2009 | Whirlpool Gold GW399LXU Gas Range
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
BO696 problems-burners too high on lowest position
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Zanussi gas stove
three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Aug 31, 2007 | Kitchen Ranges
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
190 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
