Sony KP-53S65 53 in. Rear Projection Television
Problem for Sony KP-53S65 53 in. Rear Projection Television
Need Service Mode instructions for this mode 1998 model!
By ginovino on Dec 29, 2006
I have performed the lens cleaning with surgical cotton and alcohol free cleaning fluid. I also used the same products on the mirror. The picture is amazingly brighter now! Like someone put a rejuvenator on the set. This is a 1998 model. Can the image be improved further? The user convergence still shows some overshoot of color on the cross hatch no matter what I do.
The service mode instructions,I currently have appear incomplete or I am just not knowledgeable enough to understand what it is I am looking for in the Covergence adjustment nor how its done nor how are you sure its done correctly?
I may ultimately call in a ISF Tech to align it and my new Pioneer Pro-1140HD. Though in the meantime. Any suggestions would be appreciated.
Comments:
Dec 29, 2006
- I thought this forum was for Solutions and how too's. Your comments offered none of that and served no purpose other than to bad mouth and cheap shot. This set is in a guest house on my property and it works fine and provides a satisfactory viewable TV for weekly sports enthusiasts. A little TLC will make it satisfactory for some time to come, thank you.
Jan 11, 2007
- I'd love to drive a Mercedes 500AMG Twin Turbo 12 cylinder, however practicality is more important than ego in this instance. Being able to put aside childish "I must have now at all cost", is what separates adults from spoiled brats. I do have a $4k HD unitas well and can also give credit and appreciate from whence I came viewing wise, which is more than YOUR response has provided!
Feb 01, 2007
- No I have not yet. I have a ISF Tech due to come on 2/9 to calibrate my new Pioneer Elite 1140HD and to align, Repair and generally give this Sony a proper going over. It still performs wonderfully for the most part. Pictue is bright, just that I may have not been as careful as I thought I was when cleaning the lenses & mirror. It owes me nothing since 1998! I'll keep you updated when its completed. Thanks for asking!
Feb 11, 2007
- This is to inform all readers that my worse fears were just that - fears! I had the services of an ISF technician on site to calibrate my new Pioneer Pro-1140HD and he offered for a few $ more to check/align/calibrate the Sony RPTV. (Mind you the set was never touched by anyone since it was delivered nearly 10 years ago!) Absolutely nothing wrong that its internal focus couldn't fix so he said. He gave it complete 3 hour servicing and found it badly needed 1)Internal Focus, 2)Internal convergence alignments for every axis, 3)Adjustment for overscan, blooming, 4) plus the usual ISF alignment using, signal generators, Test DVDs, and various test gear including a laptop PC with programs to autotest settings.
This RPTV is better now than the Day it first arrived in my home. Thank you to all the forum contributors who offered REAL help in solving my issues!
Best Solution
posted on Jan 13, 2007
Helpful)
mcturboz
Rank: Apprentice
Rating: 80%, 2 votes
I just did the convergence myself using this site as a guide http://www.bus.ucf.edu/cwhite/theater/Se... . I have other problems with the set but the convergence mode is easy to access and adjust. Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Feb 01, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Ginovino,
Did you ever get the convergence fixed? I was just given one of these and am having the same type of problem.
Thanks.
Solution #3
posted on Dec 29, 2006
Somewhat Helpful)
henlopen
Rank: Wiz
Rating: 84%, 649 votes
With a set that old, it is unlikely you'll get the convergence that close to perfect anyway. You may even make it worse if you go too far in your adjustments. How you could manage to even watch it after looking at a HD set is beyond me anyhow. I would sell it "as is" and stick with HDTV.
Was this helpful?
Yes
No
Solution #4
posted on Feb 24, 2007
Not Rated)
Bucth
Rank: Apprentice
Rating: 0%, 0 votes
LG Projection TV Model #RU-52SZ30 I turn on the tv 1st led light flashes yellow turns green Picture is OK.After 5sec.no sound,picture 1st and 2nd led light turns red.The 2nd led light flashes 8 times.Pls.send me solution to fix this problem. Thank You
Was this helpful?
Yes
No
Solution #5
posted on Feb 11, 2007
Not Rated)
rednose
Rank: Apprentice
Rating: 90%, 6 votes
Remove the lenses, drain,clean and refill the crt's with new fluid, adj focus and screens etc.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-53S65 53 in. Rear
Questions and Unsolved Problems for Sony KP-53S65 53 in. Rear
Do you recommend Sony KP-53S65 53 in. Rear Projection Television?
Answer
Answer
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while.... (More)
Answer
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled... (More)
Answer
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the... (More)
Answer
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The... (More)
Answer
Unable to adjust blue horizontal convergence. Can adjust vertically, but not horizontally.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-53S65 53 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
