Question about Memorex MT2245 TV
Delay turning on
I have a new Memorex Flat Screen TV, and it takes about 10 seconds for the picture and sound to appear when it's turned on. Is this normal in a new TV, or fixable? The TV was a gift and is rather heavy, so although it is under warranty, it would be complicated to return it. Thanks!
    Sergeant:
  • 308 Answers
This model uses a flat screen picture tube, and it could be that it is normal for the tube to take that long to warm up. It is also why the set is rather heavy. If you are able to return it, however -- I would opt for a "name brand" set that can at least be repaired when it breaks down. Check out consumer reports December issue for suggestions.
Posted on Dec 29, 2006
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 02, 2014 | Televison & Video
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
The T.V. turns on but no picture... the logo pops up on screen for about 2 seconds then disappears nothing happens
Sound like an inverter board problem, call around see if can get a shop that can get it for you last I checked they where no longer available. Julio - Millenium TV in Las Vegas
Dec 30, 2009 | Memorex MLT3221 32 in. LCD TV
No picture but sound. When turning the tv on the
Power supply issues - I bet bad capacitors 'dried out' .
A good servicer should be able to fix it for you.
Nov 19, 2009 | Imation MLTD3222 32 in. LCD TV
Memorex HDTV no picture
I am going to assume that you have not already found the answer to this problem. It is actually pretty common for flat panel televisions in the winter to be too cold to turn on. What I did when faced with this problem on my 32 inch memorex was turn it on for 30 minutes while covered with a fleece blanket, than turn it off. When you turn it back on it should work...did for me!
Dec 31, 2008 | Memorex MLTD2622 26 in. LCD TV
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Memorex MT2245 TV Logo
80 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
