Question about Radio Communications
Does not transmit but does receive somewhat
Radio turns on and receives (kind of on the low side) but does not transmit (the needle doesn't move). Could it be the finals?
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    Many things can cause this problem, be more specific please
  • Gene Pitts May 11, 2010
    Hello arturo garci, the finals are most likely the problem. There are several questions to pinpoint the problem, make,model,Mgfr,ect. Happy Thanksgiving & Merry Christmas.
  • 23 Answers
Yes it could be.. what kind of radio?
Posted on Mar 18, 2010
Cobra 29ltd turns on but no sound afterwards, not even when I ask for a question the needle doesn't move after I ask the question, installed in a freightliner cascadia
I guess i will have to ask you the most obvious things. Do you have a suitable antenna connected? The needle moves on receive in most cases, not transmit. A watt meter will help you know if you are transmitting.
Aug 21, 2016 | Cobra Radio Communications
Receives fine, needle does not move on transmit, transmit light lights
Needle on the meter might have went out . Is it stuck in one spot? If it moves during receive and goes to zero when keyed it most likely the final.
Mar 08, 2015 | Radio Communications
Cx80, what does the code "rx" mean on the display
  • TX = Transmit. RX = Receive. Does your needle move when you key the mic? Does it modulate when you talk in the mic? Do you have an inline watt/SWR meter inline? What kind of a set up do you have? Mobile? Base? Get back to me if you want further help.
Regards, Tony
Oct 18, 2011 | Cobra 29 LTD CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I can only hear the others. When I talk they can't hear and my red anntenna keeps coming on when I push button to talk.
Assuming the antenna is mounted and grounded correctly,when you try to transmit/talk does your meter needle move to the right with your voice,if it doesn't make sure meter knob is set to receive/transmit or mod[modulate] does it move to right now,if not make sure the mic gain knob is turned up or if it is a power mic,is it turned up&have a fresh battery.The antenna light could mean high swr readings which you will have to adjust by tuning the antenna with the radio meter or external meter,you can search swr adjustment on your computer if unfamiliar..some antenna warning lights are factory set too sensitive but most times are telling you there is a problem.If all is set&tuned properly and you still can't get a local signal to respond, your radios transmit finals could be blown,which you'll need a qualified radio tech to determine..Good luck& 73's
Aug 13, 2011 | Cobra 29 LTD CB Radio
One of the motorola radios has a lowgrade constant noise when the other is transmitting, I can hear transmissions from the other but cannot transmit
It is possibly a bad or very low battery. It takes more energy to transmit than to receive. So typically when you have a failing battery you will experience no transmit, but receive is okay. Constant, or low grade static is also a sign of a bad battery. Simple test to see if it is the battery, swap the batteries between the two radios and see if the problem moves to the other radio.
Best regards.
Aug 07, 2011 | Radio Communications
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
VHF Radios
Technically no. The reason is the receiver end would be overloaded with the signal from whichever is transmitting specially if on the same frequency. This could only be done if the frequencies of the two radios are largely apart and a duplexer/cavity filter is used. An alternative is to have a small local repeater, a single common antenna for both receive and transmit and a row of cavity filters. A low power portable anywhere in the vessel would be electronically repeated by the repeater to be received by any low power portable again anywhere in the vessel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 31, 2008 | Radio Communications
Connex 4600 turbo
It is lkikely that you burn the output transistors. You can easily check these transistors even if it is soldered but be aware of low resistance paths like coil , toroid, and lo ohm resistor which might affect the reading in the multitester. To be sure desolder at least 2 pins before testing. I do not think that the driver is damaged.
Mar 01, 2007 | Galaxy Radios DX-33HML 40-Channels Base CB...
Radio Communications Logo
95 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
