Question about D-Link DP-300U (DHDP300U) Print Server
DP-300U keeps falling off network
I have a client that has a DP-300U print server, using LPT1 on the Print server. The unit was working fine until recently (last few months), where it is no longer able to be seen on the network, accessed with browser, or accessed with included management software. After recycling the ac power several times to the unit, and then substituting a temporary (known good) ethernet cable directly from the printer server to the switch, I still experienced failure and replaced the unit with a new one. I could then immediately access the new unit and went through and created a new printer and print server port on each workstation as per instructions using, custom/LPR choices and found the print server would drop off the network after each test page was printed and would need to be powered off and back on again to become available, until the next print page was sent and it would then again fall off the network. So I changed from custom/lpr to standard/generic and each station was then able to print a test page to print server without requiring the DP-300U to have it's power recylced each time. The replacement unit worked fine for about an hour and after sending several jobs to the printer the server once again is becoming inaccessable, until the power is once again recycled to the unit. It does it intermittently, sometimes after each print job, sometimes after several print jobs. But it will always fail in a short period of time and will need to have the power once again recycled. All users are running XP Pro SP2, I have checked the firmware and the version in the Print Server is reported as 2.0, although the latest according to Dlinks website is 1.2. I have installed the latest print drivers for the HP4050 laser printer being used. The ip address is the default 192.168.0.10. The unit itself is plugged into an American Power 500va UPS, providing a source for consistent computer grade power. This certainly not the first time I have had less than satifactory results with DLink Print Servers. But I assure you it will be the last. I have experienced similar problems with their units resulting in unacceptable high failure rates. Most occuring within months of use. Each of those sites have had the eqiupment replaced with another brand and have experienced no further problems. I have been installing networks since 1986 and am not new to this type of installation. I have this site and one more that are still running Dlink print servers, and I suspect come next week I will be down to one.
  • 2 more comments
  • Rak Dsouza Nov 06, 2007
    HI,im having D-Link DP-300U print server.the problem is that the device often goes to sleep state and needs to be restarted again and again until it works!, if anyone has the solution for this i'll b very gratefull.
  • Anonymous Dec 16, 2007
    Some body please recommend a reliable Multiport Print Server
  • Masbro Feb 09, 2008
    I have three laptops wirless and two with windows Xp Pro work's fine using
    the DP300U printserver and a Linksys WRT 54GS router on the third Toshiba laptop I am using Vista and I keep loosing my printers by them going offline and can not be put online untill you delete and reinstall.
    Cant get any help including Microsoft ??
  • dgsummers Mar 20, 2009
    Same problem as describe - the print server goes off line and will not respond for my HP Laser Jet 1100A on the parallel port. It takes several power off recycles before it works again.
    Scholar:
  • 76 Answers
This print server is a problem child. Lack of sufficient buffer memory and every ever-so-slight voltage change causes this print server to die. DLink has NO good print servers as far as I'm concerned. You should replace the "other" remaining print server as soon as possible, unless you get paid for the onsite call. I've had experience with this unit. My last experience with it, though, was when I unpinched the unit from between my thumb and forefinger over a garbage can. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
4 Suggested Answers
viaujoc
  • 60 Answers
SOURCE: Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
Posted on May 11, 2008
SOURCE: can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
Posted on Dec 04, 2009
  • 24 Answers
SOURCE: hi , please i have forgot my password Dlink dp 300u ,can you help me please?
Try using the psadmin software to do a factory reset. If it demands a password to do this, try using "SYSxxxx" (where xxxx stands for the last four digits of the MAC address written on the underside of the server. If you don't have the psadmin software you may be able to download it off the internet. After doing the reset you will need to follow the Quick Install Guide to set up the server. If you lost the Quick Install Guide you can download a new one from D-link's website. The following link may also be helpful: http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
Posted on Dec 31, 2009
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
I have installed PS 300 U on my network it works fine with window XP. With windows 7, the PS 300U is not discoverable in the list of printers. However in My Network and sharing center it is listed with all...
hi
go to following link you will find your solution for PS-300U
http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/3874def4-fcf9-4513-af38-98aa33793cc2
Aug 07, 2010 | D-Link DP-300U (DHDP300U) Print Server
There is no reset button
dear
Better way when you take new dp 300u unit in box cd in cd admin software run you can reset button is there please check
May 11, 2009 | D-Link DP-300U (DHDP300U) Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
Dp301p+ psadmin password was forgoten
Problems with your D-Link DP-300U LOST IP If you’re like me, you have a ton of computer **** laying around your house. Today I found an old D-Link DP-300U print server laying around and thought that I could put it to good use. The bad thing about these things is the fact that they do not have a hardware reset button on them, so if you forget the IP or the Password, you’re pretty much hosed… or so I thought. After doing some google searches for how to find a lost IP, I came back empty. The PS Admin program that D-Link publishes for use with this thing couldn’t find it on my network either. After some thinking, I came up with an idea.
If you know anything about networking and how networks work, you should have thought about this too. Get a Wireshark capture running. Unplug the power from the print server and then replug it. It’s going to send out an ARP on the network looking for it’s gateway which should be picked up by Wireshark. It should look like this:
capture.jpg In my case, it came back as 192.168.1.253. After changing the IP on my laptop to fit that subnet, I was able to log into it via it’s web interface (there was no password on it thank God!) and put it back to factory settings. Voila! What once was a brick is now a working print server!
I Copied it!
Shafiuddin Russel
infoshafi@gmail.com
+8801714073692
Feb 16, 2008 | D-Link DP-300U (DHDP300U) Print Server
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
DLink DP-300U Print Server
What is the IP of the Print Server and the Printer itself? They have to be on a 'flat network' or the gateways of the the 'adjacent' networks have to be defined as a neighborhood.
Nov 15, 2006 | D-Link DP 300U (DP-300U) Print Server
D-Link DP-300U (DHDP300U) Print Server Logo
837 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
