Question about Lexmark X5470 All-In-One InkJet Printer
CARRIER JAM I DONT KNOW HOW TO FIX MY CARRIER JAM
  • 2 more comments
  • kilford007 Dec 21, 2008
    chewing up paper how do u dismantle it ?
  • deacon27 Jan 13, 2009
    my printer is saying please clear carrier jam. I can't see any paper jammed in the printer.
  • rainewv Jan 30, 2009
    A small sheet of file labels is stuck inside and cannot be seen, let alone felt. Is it okay to remove the back of the printer to get at the labels?
  • Hatxh Feb 03, 2009
    Traker tape off
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
861
Posted on Mar 02, 2009
What I did was fold a half sheet of paper (Sturdy enough to push whatever it is that is on the rollers.), adjusted the guiders to the middle, open the printer (Where you change the cartridges. Also make sure you have a very bright flashlight or L.E.D.) with one hand, push the paper as far as it will go, then turn off/on the power. The paper should catch something and force it out. Or you could use like three full sheets of paper to cover the full length of the paper guide. The carrier should move then.
In my case, it was a black small cable tie. Sometimes it can be paper clips, staples and small things that fall unexpectedly from the shelf where your printer is below.
I sincerely hope this was helpful to my Lexmark X5470 comrades. Oh make sure you power off then power back on and run the "Clean Cartridge", "Align Cartridges" and "Print Test Page" to make sure your printer will continue to give you awesome services!
God Bless America and the Steelers!!
~ Marco "Polo"
Posted on Feb 01, 2009
I fixed my jam by folding a full sheet of card stock in half vertically and forced it through on the same path as the labels took, in the center of the feeder. I had to turn the printer off and on several times to forced the rollers to move. After several tries, the labels came out.
Posted on Jan 31, 2009
My printer says clear carrier jam.
First remove the carrier and remove the dust and install the perfect catridge
Jan 24, 2009 | Dell 948 All-In-One InkJet Printer
Carrier jam
This strip is called the encoder strip. I found this fix online, which is very similar to the 5470.
http://www.fixyourownprinter.com/forums/printer/28494
The only difference you'll have is the encoder stip fits INSIDE the cartridge carrier. I'll attach a photo to show you where. Good luck!
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Carrier Jam
This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell 924 Carrier jam
Try and manually move the carrier. If it is stuck, dont forcefully move the carrier.
Jul 13, 2008 | Dell 922 All-In-One InkJet Printer
Clear carrier jam
There are few things you may try to fix the above problem.
Rebrick the printer. and set the printer to factory defaults
Apr 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Carrier jam
Hi , check the belt may loose , the tensioner not working or belt not in pulley alignment.
Mar 04, 2008 | Dell 942 All-In-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Carrier Jam
lubricate carrier bar with two to three drops of 3in 1oil on top of bar with power off then power on to check operation
Dec 03, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
339 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
